Looks nice Ross. What's the large diameter on it? Just trying to get an idea of the scale of the thingSteve
I'll try and remember to take a photo of the parts next to a coin or something, but there's not many of them about!
Good to see you back on the build Ross If I may offer a couple of suggestions...When possible, have the flange section of the workpiece press against the headstock end of the mandrel - that adds additional friction, and will also leave a hole with less burrs to remove after drilling. It also means you don't have to clamp down that tightly on the nut and strip out the threads, and with a piece of ordinary photocopy paper squashed in between at the chuck end, you'll get an even better friction fit with even less torque needed on the nut. It will also eliminate flex on the screwed section, and you will end up doing a more accurate job. And lastly, rather than threading the entire section on the mandrell, turn most of it to a good fit for the hole in the workpiece, and thread it to leave only a couple of thread turns inside the workpiece to allow you to tighten it down. Threaded sections are usually smaller in diameter than the actual hole, and having an entire threaded section adds a lot of unnecessary slop. Just a couple of very cheap cents from my part of the world Kind regards, Arnold
