I'm on board for the ride Ross
I messed up the centre punches
Did you center punch through the cover holes? You could have used the cover as a drilling guide, the trick being to only drill a dimple and then use that as the guide for your tapping drill later. I see you used a bolt to keep the cover in place whilst marking. I normally super glue the cover in place, drill a dimple using the clearance drill before replacing it with the tapping drill and then tapping for the first mounting stud, then add a bolt down that hole to stop anything moving before drilling and tapping the remaining mounting holes.Jo.
Looks nice Ross. What's the large diameter on it? Just trying to get an idea of the scale of the thingSteve
I'll try and remember to take a photo of the parts next to a coin or something, but there's not many of them about!
Good to see you back on the build Ross If I may offer a couple of suggestions...When possible, have the flange section of the workpiece press against the headstock end of the mandrel - that adds additional friction, and will also leave a hole with less burrs to remove after drilling. It also means you don't have to clamp down that tightly on the nut and strip out the threads, and with a piece of ordinary photocopy paper squashed in between at the chuck end, you'll get an even better friction fit with even less torque needed on the nut. It will also eliminate flex on the screwed section, and you will end up doing a more accurate job. And lastly, rather than threading the entire section on the mandrell, turn most of it to a good fit for the hole in the workpiece, and thread it to leave only a couple of thread turns inside the workpiece to allow you to tighten it down. Threaded sections are usually smaller in diameter than the actual hole, and having an entire threaded section adds a lot of unnecessary slop. Just a couple of very cheap cents from my part of the world Kind regards, Arnold
Hi everyone,snip > the aluminium plate down to size and it s square and fat! < Snip Ross
Quote from: Ross on November 04, 2012, 05:06:34 PMHi everyone,snip > the aluminium plate down to size and it s square and fat! < Snip Rossoops! you're supposed to feed the tool into it, not cottage cheese But nicely done !Bez
All in a days work!
Hi Ross.Must get meself one of those lamps, to shine into bores........ David D
Quote from: Stilldrillin on November 25, 2012, 08:46:40 PMHi Ross.Must get meself one of those lamps, to shine into bores........ David DThe lamps are very cheap, I've noticed that B&Q do a flexible clip lamp for ?8 That might be worth a look!
Another observation if I may - there are obviously lots of different ways of doing things, but the way I'd do this would be to leave the material on the parent stock for as long as possible. So rather than parting off your 4 lengths, I'd face the end of the bar, turn the intermediate diameter to the right distance from the end of bar, turn the thread diameter to the right distance from the end of the bar, put the thread on, part off to correct length. Do this for all 4, then put them back in the chuck the other way around to drill and tap one by one.
