Author Topic: Back to basics...a Finger Plate  (Read 3035 times)
Offline V 45
  • central PA...USA
« on: January 27, 2016, 11:39:26 PM »
Not sure where else to put this.... but I just finished my version of the finger plate. Most of the design came from watching a Click spring video on his finger plate. I didn't put the cross hole jig in the V groove as he did. I may at a later date. It should work great holding all sorts of little parts. The base is 5/8" 1018 steel as is the finger in 1/4". The studs are 1/4-20 all thread. The knobs are of brass with my first attempt at knurling. Not that great but functional. I also made a washer for under the hold down knob from 303 stainless steel so the brass doesn't wear to much rubbing in the finger slot..
 Thanks again,
  V 45
Re: Back to basics...a Finger Plate
« Reply #1 on: January 28, 2016, 12:04:22 AM »
Nice job Dave and I am sure you will find it useful. Looks better then mine. I did a build log on mine here..http://www.modelenginemaker.com/index.php/topic,1311.0.html
Offline V 45
  • central PA...USA
« Reply #2 on: January 28, 2016, 12:35:26 AM »
Thanks Don ! Your finger plate looks great. I don't have a "V" cutter so I used a 1/2" end mill. I had the 3 1/2" steel plate clamped to a angle plate (new acquisition from Cabin Fever) at 45 degrees. Used my 45 degree angle block I made for the scaled hoglet. Cutting down and across with each progressive pass to form the V. The same angle plate was used to cut the angles on the finger plate but it was clamped to the underside. The finger is also 3 1/2" long. It worked like a champ. It didn't look like it would but held up and no chatter. Haven't figured out the knurling completely yet. Another new toy from Cabin Fever. I picked up a scissor type tool.
« Reply #3 on: January 28, 2016, 01:11:08 AM »
The knurling looks great Dave you must of done something right. The scissor knurling is to my option the best. The V looks great and you should be able to clamp small stock to drill it.
« Reply #4 on: January 28, 2016, 01:21:25 AM »
Very nice!
I watched the video on Click Spring a while back and thought what a useful tool.
Thanks for sharing,
« Reply #5 on: January 28, 2016, 01:25:27 AM »
Dave, that looks great. I have had one of those on my to do list for a while now, just have to wait  for it to make it to the top of the list!!  Well done though and I am sure you will find it a handy addition to your tools.
I have moved the topic here where it seems to fit better. Nothing has been changed in the posts however.
« Reply #6 on: January 28, 2016, 01:29:17 AM »
That looks quality Dave.
I remember some earlier threads on finger plates...maybe the earlier forum.
Quite useful.
Offline V 45
  • central PA...USA
« Reply #7 on: January 28, 2016, 01:36:12 AM »
No worries Bill like I said wasn't sure where to put it. Thank you.
Thanks Don
Thanks Zee
Kinda stuck with the gears from my one and only ongoing build.... tools are always a welcome addition !! Looking for something else to make now. Glad you all survived the snow storm !! We accumulated 32 inches !!!
Offline philjoe5
« Reply #8 on: January 28, 2016, 01:13:08 PM »
Nice work Dave.  It looks like a handy functional tool and you finished it off nicely,
Cheers,
Phil
Offline jschoenly
« Reply #9 on: January 28, 2016, 02:31:55 PM »
Those ClickSpring videos are mesmerizing!  Fun to watch him create!  Nice work on your finger plate!
Jared
                                 Cabin Fever Expo
--- Model Engineering and Home Shop Hobbies in all Forms! ---
« Reply #10 on: January 28, 2016, 03:21:24 PM »
I had a chance to watch this one this morning, they are very well done !!
« Reply #11 on: January 28, 2016, 03:41:33 PM »
Don't forget that your finger plate, perhaps with the addition of another finger, can be used to hold short stock in the vise on the horizontal bandsaw.   With the V-groove it's already set up to handle round stock.
Offline V 45
  • central PA...USA
« Reply #12 on: January 29, 2016, 10:57:57 PM »
Thanks again everyone.
Marv...good idea about the bandsaw. I really didn't think about using it there.
