Author Topic: Contact breaker  (Read 2829 times)
Offline Tjark
  • Woldendorp, Netherlands
Contact breaker
« on: January 27, 2016, 08:06:52 PM »
I am looking for some contact breakers as in the picture but they must have a length of 40mm or shorter.
The contact breaker has to be not wider as 20mm.
I have done a surge over here but can’t find some who will fit.
The type in the picture are from a BMW motorcycle.
Maybe someone can help out.
     Tjark.
Re: Contact breaker
« Reply #1 on: January 27, 2016, 08:27:49 PM »
Is that going to be for the Kiwi?
Re: Contact breaker
« Reply #2 on: January 27, 2016, 08:30:54 PM »
I think I was given a dirt cheap Italian set of points for mine and just adjusted the bracket to fit it   ;)
Distance from the centre of the pivot to the centre of the points is 32mm
« Last Edit: January 27, 2016, 08:35:42 PM by Jo »
Online Alyn Foundry
Re: Contact breaker
« Reply #3 on: January 27, 2016, 08:32:08 PM »
Hello Tjark.
I'm going back a while but have you tried the Honda 90 cc engine contact breaker point set ? ( Pre CDI version ) They were quite compact if I remember correctly.
Kind regards, Graham.
Offline Tjark
Re: Contact breaker
« Reply #4 on: January 27, 2016, 08:57:55 PM »
Thanks a lot for the tips.
Vince sorry this is for another small project I am working on, I have bought a CDI kit in china for the KIWI.
Yes I know it’s far from original but I did not like the contact breakers on the outside off the engine.
Yo, do you know what brand its from?
Graham, thanks for the tip, will investigate f this type will fit.
     Tjark.
Re: Contact breaker
« Reply #5 on: January 27, 2016, 09:02:25 PM »
Tjark
I ordered mine from the States and the seller sent me two.  I guess he was trying to get rid of them.  If I find it I will measure it to see if it fits your requirements.
Re: Contact breaker
« Reply #6 on: January 28, 2016, 05:33:13 PM »
Found it Tjark but it's more than 40mm long so I guess it's no use to you.  It is actually a direct replacement to the one specified by Westbury for the Kiwi.
Offline Tjark
Re: Contact breaker
« Reply #7 on: January 28, 2016, 05:37:43 PM »
Hello Vince,
Thanks for the effort.
Indeed it’s a little too big for my project.
   Tjark.
Offline Longboy
Re: Contact breaker
« Reply #8 on: January 29, 2016, 07:02:49 AM »
Tecumseh small engine points and condenser. 35mm from rub block across to mounting screw. The points rubbing block surrounds the breaker cam for a compact fit and the condenser is 13 x 24mm. Sold world wide.
« Last Edit: January 29, 2016, 07:07:07 AM by Longboy »
Online fumopuc
Re: Contact breaker
« Reply #9 on: January 29, 2016, 08:22:27 PM »
I know they are very small, seen one time at a show. Maybe it is worth to ask Thorsten for the dimensions.
http://www.ts-modelldampfmaschinen.de/produktuebersicht/64-motorenzubehoer/245-unterbrecher.html
