Author Topic: Centaaur gas engine  (Read 4192 times)
Offline Frank Boyle
Centaaur gas engine
« on: January 25, 2016, 08:44:00 AM »
Hi all
I have been having a problem with the cylinder liner which is cast iron.On the mold joint and both end it was chilled.After boring the liner was slightly oval where the boring bar had flexed over the chill areas.I have spent hours lapping the bore and have got it to within 2th" I want to finish with a cylinder hone to remove the glass finish from the lap .Is 2th" near enough or have I got to carry on lapping.
Frank
Offline Manorfarmdenton
    • Fearnley Contract Services
Re: Centaaur gas engine
« Reply #1 on: January 25, 2016, 10:13:59 AM »
Frank, you have my sympathy!  Its just the sort of thing that happens to me.  I can't help but I'm very interested to see what those with experience will say.  There's a huge amount of collective knowledge on this forum!
Kind regards,
John.
John Fearnley
Offline Alyn Foundry
« Reply #2 on: January 25, 2016, 02:33:16 PM »
Hello Frank.
I'm not familiar with the Centaur engine is the liner a cast Iron tube?
Chilled cast Iron can be a nightmare, as you're left with the Silicon the carbon having migrated to warmer areas during the cooling process. In fact, for certain applications a " Chill " or " Denser " can be placed within the sand mould to produce just that effect. Certain engine manufacturers used this to produce a harder cylinder bore.
Have you tried to anneal the casting? Sometimes heating the casting up to bright Orange then burying it in warm sand can redistribute the Silicon/Carbon mix.
For the most part our moulds were poured in the afternoon and only opened the following morning reducing the risk of a chill immensly.
Kind regards, Graham.
« Reply #3 on: January 25, 2016, 05:29:39 PM »
John Deere, the blacksmith who was to become a household name (in farmhouses anyway...) pioneered a way of putting cast iron below the sand in his plough share moulds, producing a cast share with a hard layer underneath which had the effect of making them self-sharpening.  I think......
John.
John Fearnley
« Reply #4 on: January 25, 2016, 05:34:49 PM »
Frank is that 0.002" or 0.0002? if its the later then you will probably get away with it if it is two thou then I would say you need to do some more lapping.
I prefer to make cylinder liners from continuously cast bar as its nice and consistant.
Offline Frank Boyle
« Reply #5 on: January 26, 2016, 06:33:47 AM »
Thanks for your replies, it is 0.002" Jason so back to the grind.I will not buy another casting of a cylinder but do as you do and buy cast bar.The liner fits the water jacket so well that I will continue .
Frank
Offline Frank Boyle
« Reply #6 on: January 27, 2016, 06:33:12 AM »
After four hours of honing my fingers are hurting,but I have arrived at a cylinder and am going to make a plug guage before starting on the piston.My concern is that I used grinding paste to remove the chilled areas and am worried that some might have become ingrained in the cast.Although I have used thinners to clean the bore and washed it in soapy water. What is the best way to clean it.
Frank
« Reply #7 on: January 27, 2016, 08:06:53 AM »
I use brake cleaner then boil it in a pan of soapy water.
« Reply #8 on: January 27, 2016, 10:54:40 AM »
I agree with Jo about the brake cleaner.  I use it a lot.  Hot soapy water and a toothbrush after the brake cleaner would be good too.  John.
John Fearnley
Online Roger B
« Reply #9 on: January 27, 2016, 11:25:53 AM »
An ultrasonic bath is also a good option if available.
Offline Frank Boyle
« Reply #10 on: January 27, 2016, 05:32:18 PM »
I have not got access to an ultrasonic bath but I am off to buy some brake cleaner,I shouln't have any trouble with the soapy water, washing up is my province.Thanks for your help.
Frank
« Reply #11 on: January 27, 2016, 06:51:08 PM »
<<washing up is my province>>  join the club  :)  John.
John Fearnley
« Reply #12 on: January 27, 2016, 07:41:43 PM »
You need to boil it as well for a good 5 mins ;)
« Reply #13 on: January 27, 2016, 10:44:26 PM »
I thought that was what dishwashers were for  :)
John.
John Fearnley
« Reply #14 on: January 27, 2016, 11:09:04 PM »
It's worth it...no?
Yes.
