Author Topic: Gearing up  (Read 12133 times)
Offline tel
  • Bathurst District, NSW, Oz.
Re: Gearing up
« Reply #15 on: August 23, 2012, 09:43:13 PM »
Nope  :zap:
Re: Gearing up
« Reply #16 on: August 23, 2012, 10:32:22 PM »
OK  I give.....
Offline tel
Re: Gearing up
« Reply #17 on: August 23, 2012, 11:51:59 PM »
 ;) heh, heh, heh. :noidea:
Offline Dan Rowe
  • Dripping Springs TX USA
Re: Gearing up
« Reply #18 on: August 24, 2012, 12:12:43 AM »
ShaylocoDan
Offline tel
Re: Gearing up
« Reply #19 on: August 24, 2012, 01:52:01 AM »
Nope. But here's another clue - given that the 'leadscrew' will be 32tpi.
Re: Gearing up
« Reply #20 on: August 24, 2012, 01:59:51 AM »
OK 15 turns of the spindle to 1 turn of the 32 tpi leadscrew
or  about .032/15 = .0021"/ rev
Looks like a change gear banjo to me....but it's not a lathe
spiral milling attachment?   Are you going to cut helical gears on your mill?
Offline swilliams
  • Canberra Australia
Re: Gearing up
« Reply #21 on: August 24, 2012, 02:07:30 AM »
Or 15 turns of the leadscrew to 1 turn of the spindle? That sounds like something in the range to make skew gears for an oil pump or such?
Offline ozzie46
Re: Gearing up
« Reply #22 on: August 24, 2012, 02:15:30 AM »
  Cam Grinder??
Offline Dan Rowe
Re: Gearing up
« Reply #23 on: August 24, 2012, 02:20:34 AM »
Ron see reply #14 & answer reply #15.
Dan
ShaylocoDan
Offline Pete49
Re: Gearing up
« Reply #24 on: August 24, 2012, 04:21:07 AM »
back gears?
Offline tel
Re: Gearing up
« Reply #25 on: August 24, 2012, 08:22:39 AM »
 :ROFL: Yeah, they are back gears Pete - that was a given in the first post!  :pinkelephant:
Offline lescad
  • Jr. member
Re: Gearing up
« Reply #26 on: August 24, 2012, 10:41:15 AM »
Coil winder?
Les
Re: Gearing up
« Reply #27 on: August 24, 2012, 11:18:59 AM »
I think you got it Les.......
Offline tel
Re: Gearing up
« Reply #28 on: August 24, 2012, 11:32:11 AM »
 :pinkelephant: BINGO! :pinkelephant:
I thought the  :zap: would give it away!
« Last Edit: August 24, 2012, 11:36:27 AM by tel »
Offline swilliams
Re: Gearing up
« Reply #29 on: August 24, 2012, 12:34:04 PM »
So Tel - the next quenstion. Will your contraption offer any tangible advantage over winding a coil on the lathe? Is it that you just want to build your own coil winding machine? Or you'd rather have a one purpose machine you don't have to set up when you want to wind a coil? Just curious!
P.S. Come to think of it the project will allow alot of gratuitous use of the  :zap: emoticon. That's gotta be enough justification  :o
