Hi
Thanks Jon
First of all I'm not sure that this topic should continue in the Help section
Moderators please feel free to move it to the tooling section or I could start a new topic over there
As part of my post op recovery programme a little shed time has been prescribed, just a little tidying and light work to get me back in the swing of things
So I had a look at what was in the material department. This is what I came up with
Unfortunately no steel plate but the aluminium should be rigid enough.
Sorry about the mix of imperial and metric measurements, I'm just measuring what they happen to be
Starting at the back the piece of ally 7" X 5" X 5/8" should make the end plate.
The piece of ally 7" X 8" X 25mm will make the gear/handle end. I figure thats the end that will have the most effort applied, the other end just needs supporting.
The piece of ally 9 1/2" X 40mm X25mm will make the brace bar
A length of 38mm steel bar for the rolls
A short length of 1 1/2" steel bar, enough to make 4 gears
A bronze bush 1 1/4" OD X 1" ID. Enough to make 2 bushes for the gear end
A bronze bush 20mm OD X 15mm ID. Enough to make 2 bushes for the idler gears
A 25/32 reamer, the only large size reamer I have (origin unknown) For reaming the roller bushes in the end plate
A piece of 1 5/16 brass to make the roller bushes. I don't have any more usable bronze so brass will have to do
Unfortunately the large ally plate has some unwanted holes. I have turned some slightly oversize ally plugs
Pressed them in
In the mill to have a light skim. Its a little to large to do all in one go so had to be turned round.
Looks better
Back indoors now for a rest
Rich
