Author Topic: Bending rolls  (Read 30191 times)
Re: Bending rolls
« Reply #105 on: August 27, 2016, 07:32:04 PM »
The price and quality might go hand in hand here - but you solved the problem  :cartwheel:
Hope to see more now you're back on track  :)
Offline Firebird
  • East Midlands UK
Re: Bending rolls
« Reply #106 on: August 29, 2016, 07:44:22 PM »
Hi
Yes Admiral, in the end the problem was solved in less than an hour  :facepalm:
The rolls have been zinc plated and the gears have been blacked
Rich
Offline Firebird
  • East Midlands UK
Re: Bending rolls
« Reply #107 on: August 30, 2016, 08:58:11 PM »
Hi
The cross bar is made from ally. It is fixed to the 2 end plates with an 8mm and a 6mm countersunk cap head in each end.
Here the cross bar is being drilled for the 8mm
Bolted to one end and using one of the rolls to align it the other end is marked with a transfer punch
Then drilled and tapped for the 6mm
All the parts assembled
A temporary stub is turned from ally for the gear and drilled 6mm
It is used to marked its position with a transfer punch
I had hoped to get more done today but No. 2 grand daughter turned up, she's 3 1/2, and insisted we play :) :Lol:
Rich
Offline Firebird
  • East Midlands UK
Re: Bending rolls
« Reply #108 on: September 03, 2016, 06:46:44 PM »
Hi
Turn a boss for the gear, drill 6mm and counter bore
using a transfer punch to mark the position
The handle is made by drilling out a piece of steel to 20mm. I forgot to take a photo of a previous operation. The steel piece is centred under the mill then moved over 10mm. It is then drilled through with a 3/16 drill, this is a start for the keyway which is then finished by hand with a file.
The handle is made from some 3/16  x  1 1/2 flat steel bar. one end is chain drilled to remove a semi circle.
I then mig welded the 2 parts together. I'm new to the dark art of mig welding so it's not pretty.
The handle is made from a piece of ally bar with a bit of loose fitting chrome tube
I couldn't resist trying it out with a bit of 3mm  x  25mm ally
There is still some more to do but it works  :whoohoo:
Rich
Re: Bending rolls
« Reply #109 on: September 03, 2016, 07:00:50 PM »
That is quite an impressive rig there Rich. Well done!!
Re: Bending rolls
« Reply #110 on: September 03, 2016, 08:13:42 PM »
Looks good Rich, you will soon have some wheels for that portable :)
Offline Firebird
  • East Midlands UK
Re: Bending rolls
« Reply #111 on: September 04, 2016, 08:49:26 AM »
Hi
Thanks Bill
I'm going to have a go at wooden wheels for the portable Jason, doe's the brown stuff roll ok
  :thinking::ROFL: :lolb:
Rich
Re: Bending rolls
« Reply #112 on: September 04, 2016, 09:14:54 AM »
That is indeed a useful tool  :praise2:  :ThumbsUp:  :wine1:
Re: Bending rolls
« Reply #113 on: September 04, 2016, 11:10:07 AM »
Yes but it rolls better with a steel tyre around the outside ;)
If you do want to try rolling the wood then the plated rolls are a good idea as the wood will need to be steamed and that would make any bare steel rusty :-[
Offline Firebird
  • East Midlands UK
Re: Bending rolls
« Reply #114 on: September 10, 2016, 08:01:14 PM »
Hi
Complete, finished.  :whoohoo:
The handle painted, the steel gear bosses zinc plated, a drop of oil here and there and it works.
Rich
Offline Steamer5
  • The "Naki" New Zealand
Re: Bending rolls
« Reply #115 on: September 10, 2016, 11:40:55 PM »
Hi Rich,
 They have come out nice!
You thinking of going into production..... :stir:
Cheers Kerrin
Re: Bending rolls
« Reply #116 on: September 11, 2016, 12:49:38 AM »
Excellent work, Rich! Pinch rolls like that, only a bit longer, have been on my list for some time. Too long! Your build has encouraged me to get going on them!
Offline Firebird
  • East Midlands UK
Re: Bending rolls
« Reply #117 on: September 15, 2016, 08:39:53 PM »
Hi
Thanks Pete
Kerrin, no production I'm afraid, building one set was enough :ROFL:
Rich
