I am considering moving to a retirement apartment and consolidating my shop. The SouthBend and the Derbyshire lathes would go. The F2 would go leaving the F1 for tiny milling operations.The 10" SouthBend is too large, though it is in perfect condition and fully kitted with accessories. The dearly loved high precision Derbyshire doesn't do everything I want. Do I make a power traversing feed for it? They exist but are not to be found.So, what is there in lathes?Benchtop in size, probably 4" swing, power traverse, quickchange gear box. High precision.I think Sherline is out because of it's aluminum wiggly construction.What about Cowells? Are they sold in the US? Will they do the job?Mosey :node:
Thanks, Jerry, you have given me alot to think about. I wonder what fact vs. fiction you are referring to? The lathes mentioned are all interesting. The Levin, similar to the Derbyshire in some ways, is probably unaffordable. The Cowells perhaps unobtainable. The Sherline has a wide range of accessories available, which is appealing. I have their rotary table and chucks which are good. I will try your test with my present equipment to see how it goes. I will have a good look at the Sherline CNC and metric threading version. I assume that there is no threading dial available for it.This is going to be a fun adventure.Mosey
Jerry Thanks for your informative post; is this test done on a stock lathe; using standard available speeds and tail stock hand wheel?Dave
Bill, please feel free to indulge your naughty side.Jerry, I think you are saying that power feed is not desirable or necessary on a micro lathe. If so, wouldn't the Derbyshire then be a good choice? It could easily be fitted with an adjustable (Sherline) collet or chuck holding tailstock. A hand wheel for threading can be added.Thanks for your continued input and schooling.Mosey
