Author Topic: Dovetail milling advice  (Read 8731 times)
Online sco
« on: July 20, 2012, 12:59:52 PM »
Planning on having a go at milling a dovetail at the weekend for a spherical turning tool - detail looks like this http://metal.duncanamps.com/images/hk1160_head.jpg (This is obviously someone else's attempt at the same part).  I'm going to mill each side of the dovetail separately but is there anything special about dovetail milling I should know or just procede as per normal milling?
Cheers for any advice,
Simon.
Ars longa, vita brevis.
Re: Dovetail milling advice
« Reply #1 on: July 20, 2012, 01:29:51 PM »
If you are making it as separate parts like in your picture then you don't need a dovetail cutter, just set the work at teh correct angle and mill across teh end with a standard bit or even flycut, it helps to cut teh angle onto the end of a longer bar and then cut it off once the angled part is done.
Used the method for this gear selector
Offline BillTodd
    • Bill's website
« Reply #2 on: July 20, 2012, 06:17:58 PM »
To preserve the edge of your dovetail cutter, mill out as much as possible with an end mill & T slot cutter .
Offline Stuart
  • Tilchestune UK
« Reply #3 on: July 20, 2012, 06:44:05 PM »
use plenty of coolant or cutting oil
run it at speed that is worked out for the large end , don't let it rub and do not be afraid of it give it a fair cut your machine will tell you if it is unhappy
for a 25 60deg cutter in steel i would run at 320 x 20 / 25 = 256  on a sx3
20 is the cutting speed for steel in metric bits  and 25 is the cutter big end in mm
Offline Bill Gruby
« Reply #4 on: July 20, 2012, 07:12:50 PM »
 Can't add anything to that answer, well done "Lordedmond".
 "Billy G"
« Last Edit: July 20, 2012, 07:21:15 PM by Bill Gruby »
Online sco
« Reply #5 on: July 20, 2012, 07:15:53 PM »
Thanks for all replies - I'm going to have a go with the cutter directly as it's difficult to set up the angles to end mill out the shape.  It will be done in the lathe so will have to be quite gentle cuts as the vertical slide is not a very rigid setup.  I'll see how I get on.
Offline Stuart
  • Tilchestune UK
« Reply #6 on: July 20, 2012, 07:19:36 PM »
careful when you break out nip up the slide a bit to stop it snatching
good luck
Bogstandard
« Reply #7 on: July 20, 2012, 08:20:22 PM »
Just to add a little to the explanations given.
The deeper you go into the cut slow down your feed. When you first start, it is only the tips that are in contact, so removing little metal, the deeper, the more metal is being removed.
Dovetail cutters are about the most easily damaged, and usually most expensive, cutter you own, so take care of them. I am still using a 1" one that I bought about 20 years ago, the best ?5 I ever spent.
Online sco
« Reply #8 on: July 20, 2012, 09:48:04 PM »
Well so far so good - been taking small cuts so it's going to take a while but I'm easing the feed as the cut width increases.  Seems to be cutting nicely with no chatter.   Cutter was a secondhand punt off ebay for ?10.
Online sco
« Reply #9 on: August 09, 2012, 02:34:03 PM »
All finished - here it is, quite satisfying to use;
 <a href="https://www.youtube.com/watch?v=UVc0ZbVQVoE" target="_blank">http://www.youtube.com/watch?v=UVc0ZbVQVoE</a>
Offline Stuart
  • Tilchestune UK
« Reply #10 on: August 09, 2012, 03:22:46 PM »
well done with the dove tails and the added bonus of a very useful tool as an end product
Offline smfr
« Reply #11 on: August 09, 2012, 04:15:18 PM »
Ooh that's nice. I like the idea of a toolpost-mounted ball turner. The carriage-mounted ones don't have enough clearance under the chuck on my machine, so you can't get close to the chuck jaws.
Simon
