Meanwhile I examined the Nautilus's engine with a fascination easy to imagine."You observe," Captain Nemo told me, "that I use Bunsen cells, not Ruhmkorff cells. The latter would be ineffectual. One uses fewer Bunsen cells, but they're big and strong, and experience has proven their superiority. The electricity generated here makes its way to the stern, where electromagnets of huge size activate a special system of levers and gears that transmit movement to the propeller's shaft. The latter has a diameter of 6 meters, a pitch of 7.5 meters, and can do up to 120 revolutions per minute."
I saw the Monitor steam engine thread by zeeprogrammer and I wonder how that design will be implemented with solenoids as you show. The engines I have seen use two opposed pistons and cylinders driving a rocking arm at each end, and the other end of the rocker arms each have two sets of connecting rods, one to the power crankshaft, and the others to the control valves. I realize the illustration is a "teaser" and much detail is forthcoming, but I cannot see how all four solenoids can be used for power. My other concern is that, unlike steam, which has a constant linear thrust, the solenoid's pull increases exponentially as the plunger travels from its maximum distance to the minimum distance between the magnetic pole faces. According to what I found, the force at 5 mm might be 0.75 N, and at 1 mm it is ten times that, or 7.5 N. It might be possible to design the rocker so that the solenoid is first energized with the rocker arm at right angle to the force, for maximum mechanical advantage, and then be at a smaller angle when the force is greatest. It might also be possible to have a "double acting" solenoid that pulls in either direction toward its center, and that may have a more linear relationship, but probably not as much maximum force. A permanent magnet "piston" might allow the current in the solenoid to be reversed to act in a pushing as well as pulling motion. It will be interesting to see what you finally come up with. And nice work on the curved spoke flywheel! But using CNC is cheating, just a bit...
Yeah, I'm just jealous because I don't have CNC. But I bought two Powerball tickets, so, maybe...
