Author Topic: Economy restoration  (Read 10625 times)
Offline Chipmaster
Economy restoration
« on: January 05, 2016, 11:37:00 PM »
Almost two years ago I bought a dismantled Economy model engine from a widow. She told me that her late husband hadn't managed to get the engine to run properly and she remembered him starting to make a new piston for the engine. All of the castings are iron, it was just as well it was dismantled because it's too heavy for me to lift it when assembled!
The engine came with the original plans and the box of parts was virtually complete. There was also a trolley for the engine with a nice set of cast iron wheels about 4" diameter.
The aluminium piston looked as though it had seized or perhaps there was an alignment problem. There were no piston rings in the box, that might have told a story. However, the bore of the cylinder looked good, I wondered whether it had overheated or run with insufficient oil. the clearance between the piston and cylinder appeared to be adequate. When assembled all the fitting was accurate and the running gear was nicely machined. My main concern was that the crankshaft was at a right angle to the cylinder, fortunately the alignment was perfect and everything turned over without binding.
It seemed that most of my effort would be making a piston, piston rings, fettling the castings and cosmetic work. I had other models under construction so the Economy had to take a back seat.
Andy
« Last Edit: January 13, 2016, 06:05:18 AM by Chipmaster »
Re: Economy restoration
« Reply #1 on: January 06, 2016, 01:40:28 AM »
That is a fine looking engine Andy, and a large one at that!  So where are you in the restoration? Obviously you have done a lot of looking and measuring and checking things out. Have you started on the new piston yet? Can't wait to see this one running and it seems like it won't take too much to get it there.
Offline Chipmaster
« Reply #2 on: January 06, 2016, 07:48:31 AM »
Hi Bill, the Economy engine is coming along nicely, I'll add photos of my work.
The first job was to hone the cylinder bore then make a new aluminium piston as specified in the plans.
I milled out a deep slot in the end of an aluminium bar for the interior of the piston then transferred it to my lathe to complete the job - boring the inside of the piston skirt, machining the outside diameter and forming two piston ring grooves. The completed piston was then parted off and mounted on a V block held in a 4 jaw chuck to bore the gudgeon pin hole. Meanwhile a good friend Ray turned down about eight inches of 3" cast iron bar to 2" for me to make 1.75" od piston rings.
Andy
« Last Edit: January 06, 2016, 08:15:54 AM by Chipmaster »
Offline Ian S C
« Reply #3 on: January 06, 2016, 12:30:06 PM »
Could the problem be the grade of aluminium used for the piston picking up on the iron bore, or the rings a bit tight. In an ideal world would a cast iron piston be better? :thinking:
Ian S C
Offline Chipmaster
« Reply #4 on: January 06, 2016, 05:09:06 PM »
Maybe ithe wrong grade had been used Ian and I agree I could have used continuous cast iron bar to make a new piston as I have on my other engines. However, at the time I felt like a change from cast iron - easy to machine but such dirty stuff, and tried aluminium as specified by the plan. I don't know the grade of  aluminium I used but the engine has run for a few hours and the piston looked fine when I took the engine apart for painting. I'll keep an eye on the aluminium piston, I can easily make an iron piston if necessary.
Andy
« Reply #5 on: January 06, 2016, 07:51:08 PM »
I can't see from the pictures if there are any balance weights on the crank. Changing from a Al to a CI piston will more than double the weight and upset the balance.
« Reply #6 on: January 06, 2016, 08:46:48 PM »
You want about 0.003" per inch dia clearance on the piston, well thats what I allow on an aluminium one in an iron bore.
The photos is a bit out of focus but are the marks even all round or off to one side, if teh gudgeon pin in not square to the bore it may have twisted the piston sideways.
Not seen a piston with that tapered type of skirt before.
Offline Chipmaster
« Reply #7 on: January 06, 2016, 08:48:52 PM »
You're right Roger, I also reckoned a cast iron piston could make the engine more unbalanced. There are no balance weights on the crank. I tested the engine as soon as I had made a new piston and rings, when running at a low speed the engine was quite docile and stable. However, when the revs were increased it really danced about even when clamped to my hydraulic lifting table. This was not helped by the way the flywheels were machined. Whilst the outer rims were concentric with the hubs the inner rims hadn't been machined at all and were way out. I spent a lot of time trying to retrieve the situation but you can only do so much with a spoked flywheel that wasn't set up properly at the outset. The man that built the engine had a Myford Super 7 lathe so I suspect he had to get someone else to machine the 10.5" flywheels for him. The workmanship on the flywheels was of a much lower quality than the rest.
Andy
Offline Chipmaster
« Reply #8 on: January 06, 2016, 09:21:24 PM »
Hi Jason, yes that was indeed a poor picture, the damage was all round the piston. I was tempted to try cleaning it up but decided to make a new piston, it didn't take long. I don't remember the clearance I allowed but it seemed ok when I tested the engine. The conical piston skirt was new to me, it's in the plans. It was sufficient to allow for the connecting rod movement and might contribute to keeping the piston in shape.  :-\
Andy
Offline Chipmaster
« Reply #9 on: January 06, 2016, 09:42:14 PM »
My friend Ray kindly spent some time turning down about eight inches of a 3" cast iron bar to 2" for me to make 1.625" od piston rings. After machining the od and boring out the centre I ground a very narrow tool so that I could part off as many rings as possible.
Each ring was cracked open by placing it on a steel bar held in a vice then placing a knife blade against the ring and hitting the back of the blade with a small hammer.
For heat treatment a nut was placed between the open ends of the ring which was then heated to red heat and left to cool. Each ring had just the right amount of 'spring'.
The next task was to gently polish the rings using fine emery cloth on a surface plate until they were a sliding fit in the piston grooves. And finally the ends of the ring were filed to achieve the desired gap when fitted in the cylinder bore.
Andy
« Last Edit: March 23, 2016, 10:32:22 PM by Chipmaster »
Offline Chipmaster
« Reply #10 on: January 07, 2016, 05:54:23 AM »
The engine was reassembled with it's new piston and jury rigged for a test run. I couldn't get on with the carburettor that came with the engine so I borrowed the mixer from my Alyn Foundry RLE engine and the engine started easily and ran pretty well. You can also see how the inner rims of the flywheel are not concentric.
Here's the engine running faster, much faster than I'd normally run this type of engine.
Andy
Online rudydubya
  • Western Arkansas USA
« Reply #11 on: January 07, 2016, 07:37:21 AM »
I love the way it runs, Andy.  I played the videos several times just to listen to it.  Thanks for sharing.
Rudy
Offline Chipmaster
« Reply #12 on: January 07, 2016, 09:28:39 AM »
Cheers Rudy, I like to have the engine running as slow as possible.
Here are a few video clips of the engine running on propane. Didn't bother with a demand valve, simply connected up the gas supply with a rubber tube, set the pressure down to about 1 psi and she started quite easily.
After some extended runs to satisfy myself that the engine was sound I took the engine apart for fettling and cosmetic treatment.
Andy
Offline Chipmaster
« Reply #13 on: January 07, 2016, 09:57:39 AM »
The flywheels needed a lot of work. I have circled two holes in the picture below. These were a legacy of drilling a bolt hole through the clamp section of the flywheel. I think most builders wouldn't bother to drill such holes but it was very well done,  the saw cut in the hub copied full size practice and it does facilitate tight fitting of the flywheels on the crankshaft. I wanted to fill the holes and make them inconspicuous. The machining marks left on the flywheel rims had to be sorted out, the inner rims needed machining and the spokes needed fettling.
Andy
« Last Edit: January 07, 2016, 10:53:46 AM by Chipmaster »
Offline Chipmaster
« Reply #14 on: January 07, 2016, 08:48:25 PM »
I cleaned up each hole in the flywheel rim with a 5/16" reamer then made tight fitting cast iron plugs threaded to accept a 2BA countersunk socket screw. The countersunk head overlapped the 5/16" hole and the screws pulled the cast iron plugs into the holes. I applied a copious amount of Loctite 638 to both screws and plugs. After the rim had been machined you could still see the plug if you looked for it but it was a big improvement on the holes.
The person who carried out the machining of the flywheels failed to centralise the hubs and rims on their faceplate before boring out the hubs. I did the best I could to improve the appearance of the flywheels but decided I could replace them if they let the rest of the engine down. After extensive fettling using grinding points in a Dremel, I used Upol Dolphin Glaze car body filler to build up the surfaces for painting.
Andy
