Author Topic: 5 cyl radial with overhead cam  (Read 7933 times)
Offline Brian
Re: 5 cyl radial with overhead cam
« Reply #15 on: January 24, 2016, 02:35:10 PM »
Hi all
 if you want to catch up on this thread you may like to look at <a href="https://www.youtube.com/watch?v=5BAUrD6AsII" target="_blank">http://www.youtube.com/watch?v=5BAUrD6AsII</a> this is the first of three
slide shows with a little video added.
 Sorry I am not very good at downloading  or making video yet  I hope to improve  but it is another call on my poor 75 year old brain.
Brian  H
« Reply #16 on: January 24, 2016, 03:04:08 PM »
Great slide show Brian.
I hope to see the other two.
Offline Brian
« Reply #17 on: January 24, 2016, 06:05:01 PM »
Ok  Carl No 2 coming up
Brian.   H
<a href="https://www.youtube.com/watch?v=KsJvTsjiQIc" target="_blank">http://www.youtube.com/watch?v=KsJvTsjiQIc</a>
Offline Brian
« Reply #18 on: January 24, 2016, 06:07:59 PM »
I cant seem to get them all on one post so here is No 3
Brian  H
<a href="https://www.youtube.com/watch?v=smCKkDWyY-A" target="_blank">http://www.youtube.com/watch?v=smCKkDWyY-A</a>
« Reply #19 on: January 24, 2016, 07:38:20 PM »
Thanks for taking the time and trouble.
I enjoyed!  :ThumbsUp:
Offline Brian
« Reply #20 on: February 06, 2016, 07:44:02 PM »
At last i have good results . thanks to all the help.
the cages are in and look good so far  when I have the valves made I will built a test set to prove the sealing.
I have done another Video it's not good  I lost the captions in the download  You can see it on my channel ( brian hogger) but I will try to load it here.
<a href="https://www.youtube.com/watch?v=dTrIgprpNIQ" target="_blank">http://www.youtube.com/watch?v=dTrIgprpNIQ</a>  To see if it works.
Offline Brian
« Reply #21 on: February 07, 2016, 06:09:55 AM »
I think I have it now
<a href="https://www.youtube.com/watch?v=dTr1GPrpN1Q" target="_blank">http://www.youtube.com/watch?v=dTr1GPrpN1Q</a>
Keep fingers crossed.
Offline Brian
« Reply #22 on: February 16, 2016, 04:20:40 PM »
The next part is the cam box a small piece of aluminium with lots of holes just trying to get them to miss each other is a major achievement. lots of holes and no room.
Brian H
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #23 on: February 16, 2016, 06:09:34 PM »
Looks good Brian.  :ThumbsUp:
I'm looking forward to see more.  :cheers:
Offline V 45
  • central PA...USA
« Reply #24 on: February 19, 2016, 11:11:03 AM »
Looking good! Looking forward to seeing more
Offline Brian
« Reply #25 on: February 25, 2016, 07:44:46 PM »
A quick update on progress.
The camshaft has been cut and fitted in the cam box with Oilite bearings,
I am waiting for the screws and tap to arrive so I can assemble the head, then the next step is to
 cut the valves to length and set the valve clearances.
When I am happy that it all works correctly the edges at the front of the box formed to match the curve of the head.
Brian
Offline Brian
« Reply #26 on: March 26, 2016, 03:51:59 PM »
Ok off we go again. the next job was to establish the length of the valves and then drill the hole for the pin.
the valve lash is minimal the followers just clear the base circle, the thinking is that the head is likely to expand more than the valve so clearances will increase when the engine is hot.
The head was then given a test run on the lathe, all seems OK the followers are revolving in the guides to  spread out the oil film  and reduce wear  so I am a happy bunny.
Brian.http://www.modelenginemaker.com/Smileys/default/happy-132.gif
« Reply #27 on: March 26, 2016, 04:26:03 PM »
Looking good  :ThumbsUp:  :ThumbsUp: Four more to go  ;)
Offline Brian
« Reply #28 on: March 26, 2016, 08:47:32 PM »
Further work done to tidy up the appearance and fit the timing gear that turned out to be not as ordered so I await a reply from the company.
Brian.
