Author Topic: Suzanne needs your help  (Read 6686 times)
« on: December 22, 2015, 04:11:41 PM »
Today I was given a set of castings for Suzanne. The problem is that no one has any drawings for her  :(
I was wondering if anyone knew where I might be able to get some from.
P.S. She's in your favourite colour scheme Don  :mischief:
Re: Suzanne needs your help
« Reply #1 on: December 22, 2015, 04:26:59 PM »
I've seen here somewhere, just need to remember where.
Has someone swapped that nice spoked flywheel for a nasty disc one :(
Failing that there is not much to the girl, you should be able to draw something up for her, what sort of size is she?
« Reply #2 on: December 22, 2015, 04:29:43 PM »
« Reply #3 on: December 22, 2015, 04:47:32 PM »
I have that one as well just it was hiding on a stack of other flywheel castings when I took that photo :naughty:
« Last Edit: December 22, 2015, 05:03:08 PM by Jo »
« Reply #4 on: December 22, 2015, 05:03:13 PM »
You best show us those as well just incase they need identifying.
Did you see the price of the castings on Atelier's site, don't let Uncle E know :-X but I'm sure you can afford a set of teh drawings and still be quids in :cartwheel:
« Reply #5 on: December 22, 2015, 05:19:15 PM »
I have the drawings for the JC Diesel  ;) but need them for the others.
 :o I had not seen that.  :-X
« Reply #6 on: December 22, 2015, 05:47:23 PM »
Quad Victoria? Double tandem Tangye and a Stuart horizontal. You will be busy.
You could do one double victoria as per Stuarts and the other as Samson & Goliath that were in ME
Das Dampf-Modell 1995 No 2 has the table engine in it - article by the designer Dietmar Carsten
« Reply #7 on: December 22, 2015, 05:58:55 PM »
:ShakeHead:
You need to look more closely at the castings :naughty:
Thanks found that old mag of mine  :)
« Reply #8 on: December 22, 2015, 06:23:15 PM »
Missed the fact the trunk guides are closed at the ends so looks a bit like the Lincoln from Southworth so possibly the twin tandem compound.
Oh, I see modified cylinder mountings :whoohoo:
« Reply #9 on: December 22, 2015, 06:45:52 PM »
Jo, your going to need a building just to house all those casting you been hoarding girl. That is just awesome and multi tasking, your just the tops............ :ThumbsUp:
« Reply #10 on: December 22, 2015, 07:18:20 PM »
 :embarassed: Thanks Don, As we are coming to the end of the year I had to make up for sticking to my new year resolution for so long. Next year will be a new resolution >:D
I am still short of some drawings :( I am not sure that the Suzanne castings are the same as the Dora one so if any one can help   :)
« Reply #11 on: December 22, 2015, 07:41:42 PM »
Could the Suzanne have been from GLR as they used to do a few of those designs under different names like the wall engine Rachael which is also sold as Elaine in Europe.
« Reply #12 on: December 22, 2015, 07:46:00 PM »
 :thinking: Well I am told they predate the German mag article and presumably the Atelier set by at least 10 years.
« Reply #13 on: December 22, 2015, 08:10:41 PM »
Gusteile (M Burkhand) did the castings as well and thats probably pre Atelier. Bau Plan also did the drawings
The style of that name plate is just like the other GLR engines.
« Reply #14 on: December 22, 2015, 08:13:48 PM »
Appears to be a nice score, but, I have a question.  Now I know I'm very, very,  uneducated when it comes to things like this, but, I notice so many times you guys come up with castings with longer names than a lot of Southern U.S. girls ( country girls ) and then the drawings are harder to find than a honest politician  :shrug:.
I just wonder  :DrinkPint:
Cletus
Just read last post, y'all do a bunch of name dropping too,  don't you?
