After building my engines I enjoy running them and testing how well they will run which usually means seeing how little air pressure they need or how slow they will turn, so gradually I have added different measuring devices and methods of testing. This lead to a confusing array of gadgets and wires so I thought it was time to bring it all together so here is my test centre with every thing in one block.
I recently added a airflow meter and found the reading pulsated with piston rhythm so I decided I needed a buffer tank to smooth out the pulses, so I used a length of Ali box section and plugged the ends with Maple rebated in and sealed, This gave me a flat surface to add the other gauges and for it to stand up. To Test for leaks in the engine I charge the compressor up to say 5psi and stop the engine at TDC and see how much air is leaking out, and then try other positions and test them. You will notice my Airbrush compressor has 2 regulators, one set at 16psi and the other at the lower level you need and I found this keeps the pressure constant throughout the run. I leave it here for the moment and I might do a video.
Geoff
