It will be interesting to see how it will be fixed to the grinder. It think the Worden has the facility to use it. What drill sizes does it take?Vince
Thinking about raising the grinder on some sort of platform in relation to the grinding jig so that the direction of grind is more favourable, it is now more or less parallel to the cutting edge. I believe it would be better to grind allmost at the 6 o clock position on the wheel.
Looks like it's doing a good job!
