Author Topic: Back gear help  (Read 4475 times)
Offline PJW
Back gear help
« on: November 26, 2015, 11:50:51 AM »
I got a Cowells 90 lathe yesterday & was looking at the back gear, I can see how to engage it but how do you release the gear to operate it? I have been after a good Cowells for quite a while, but they are so expensive & you need it well equipped. Mine is well equipped but needs a tail stock chuck, so if any of you have a spare or know where to obtain one at a realistic price please let me know!
Peter
Old Guys Rule the Dark Side of the Shed!
Re: Back gear help
« Reply #1 on: November 26, 2015, 11:58:07 AM »
 :pics:
This is what you need  ;).
Offline PJW
Re: Back gear help
« Reply #2 on: November 26, 2015, 01:00:52 PM »
Thank you Jo, & sorry about no pic
Offline PJW
Re: Back gear help
« Reply #3 on: November 26, 2015, 01:06:01 PM »
I need switches & a v belt & as I said a chuck for the tail stock then I can start using it in anger, i have a handbook in the post so no more sill questions from me.
Offline Alyn Foundry
Re: Back gear help
« Reply #4 on: November 26, 2015, 01:51:06 PM »
Dear Peter.
I notice in your photo above you already have a Jacobs style chuck, perhaps a chat with Chester machine tools about a suitable arbour would help? They also carry a range of Vee belts and NVR switches.
I'm a bit biased but shop around, perhaps even try the despised ebay!!
Kind regards, Graham.
Re: Back gear help
« Reply #5 on: November 26, 2015, 01:53:06 PM »
As you say that looks nicely kitted out and the tobacco tins give a good idea of the size  :)
Re: Back gear help
« Reply #6 on: November 26, 2015, 01:58:14 PM »
The Cowells taper is a short 0MT (the wrong end to make use of commercial 0MT ones :ShakeHead:)
The Vee belt is a standard sewing machine belt, I think 6mm  but once you get the book will tell you the sizes (the toothed Cowells ones are very good/expensve). Mine cost me a lot less than £10 delivered  ;) The lengh of the rear belt will depend on where you mount the motor.
That is a capacitor start and run motor. Do you have the capacitor for it?
Offline PJW
Re: Back gear help
« Reply #7 on: November 26, 2015, 02:29:18 PM »
thank for all the info & Jo I did not know about the 0 MT being short as I was going to buy a standard 0 mt arbor, so any help with the arbor anyone PLEASE
Offline PJW
Re: Back gear help
« Reply #8 on: November 26, 2015, 02:31:59 PM »
Yes I have the capicitor & I believe it will run in both directions but I dont know how to wire it up to do this
Offline PJW
Re: Back gear help
« Reply #9 on: November 26, 2015, 02:55:12 PM »
I have just been on cowells site & the cheepest chuck they have is £60 with vat ouch!
It looks like the previous owner has made on arbor I dont know what size it is, its a short 0 mt & the other end the chuck taper which is
11mm on the small end, 12.4 on the large end of the taper & the taper is 27.5 long, any one know what this is?
Re: Back gear help
« Reply #10 on: November 26, 2015, 04:04:07 PM »
Dear Peter.
Try this.  http://littlemachineshop.com/reference/tapers.php
As for std arbours just take a saw to it!! There was one machine in the Chester range that had a short arbour requirement I used to prepare batches of short stub on a regular basis.
Cheers Graham.
Offline PJW
Re: Back gear help
« Reply #11 on: November 26, 2015, 04:29:06 PM »
Hi Graham, i checked out the taper charts and nothing seemed to mach up with mine and for the 0mt short according to Jo who has a Cowells lathe you need the small end of the taper so it doesn't seem like the saw would do the trick, sadly.
but thank you very much for the help,
Peter
Re: Back gear help
« Reply #12 on: November 26, 2015, 06:03:39 PM »
It looks like your taper may be an extended B12. It should be Large end 12,065mm Small end 11,1mm Length 18,5mm Extending this to 27.5 mm gives a large end of 12.48mm with a small end of 11mm.
Can you beg or borrow a B12 taper chuck to try?
Online Twizseven
Re: Back gear help
« Reply #13 on: November 26, 2015, 06:31:37 PM »
Hi there,
Looks like you had a good buy, lots of goodies with it.  I had seen that one on Ebay a few days ago.  I bought mine as an Ebay purchase early last year and have been very pleased with it.  In fact it is just about to have a present of a set of DRO's fitted based on the Magnetic read heads sold by Allendale, and using the Yuri's Toys Android package Touch-DRO as the display console.  I am trying to get up courage to drill the carriage for the mountings at the moment.
I'm sure you will have fun with it.
Colin
Offline PJW
Re: Back gear help
« Reply #14 on: November 26, 2015, 08:11:03 PM »
thank you roger, that sounds right.
Yes Colin that was my lathe, I have just rough wired the motor up and it worked, it was turning the wrong way but a two second fix. I got all the items shown in the pic plus two other boxes with useful bits in. sadly no drill chuck or live centre.
