It is possible to use soft solder on aluminium. Scrape the surface to be soldered to get rid of the oxide film, and immediately cover with clean oil(this keeps the air away from the metal), using a big soldering iron, the one I use is about 30 mm sq x 90 mm long copper part, or the 175 Watt electric iron, put that on the aluminium through the oil and heat the metal, rub the iron firmly across the surface and add the solder. Wipe the excess oil off, place the tinned brass on the solder surface of the aluminium and heat with the iron until the two parts are sweated together, hold the parts together until cool, that's it.
Learned to do that soldering earth straps to aluminium radio chassis.
Ian S C
