Author Topic: Parsell & Weed Horizontal IC Engine  (Read 139333 times)
Re: Parsell & Weed Horizontal IC Engine
« Reply #660 on: August 19, 2016, 11:47:07 PM »
How did you know I had one in hand Cletus . You got a drone outside my window or something?  :lolb:
Prof.
« Reply #661 on: August 19, 2016, 11:59:57 PM »
It's Friday, Zee and I wager on who starts first every week :lolb: :lolb:
Cletus
« Reply #662 on: August 20, 2016, 12:12:23 AM »
Hmmmmm...that's a tough call...lol.
« Reply #663 on: August 20, 2016, 12:33:26 AM »
Cletus
OH SURE...............you folks back East always get a head start!   :DrinkPint:
« Reply #664 on: August 20, 2016, 12:45:59 AM »
G&T ?
« Reply #665 on: August 20, 2016, 12:48:47 AM »
G&T ?
I'm thinking "Gin & Tonic", Dave.  That's what it means to me anyway.  ;)
In 42 minutes I'll be having one myself while watching "Reality TV" aka "The National News"!  :Lol:
« Reply #666 on: August 20, 2016, 12:53:23 AM »
Ah makes since; I was thinking that it was some brand of beer; but I'm a beer drinker so that is where my mind went.  :lolb:
I do like G&T's though and occasionally a nice Martini.
« Reply #667 on: August 20, 2016, 01:07:58 AM »
G&T ?
Yep, you are absolutely correct Jim.
« Reply #668 on: August 21, 2016, 04:02:31 PM »
I am posting a few pictures of the new riser blocks and tailstock extender below. Progress on the flywheel(s) will be posted later this afternoon...after I make some progress :)
Photo 1 is the headstock riser, photo 2 the tailstock riser, photo 3 the tailstock extender (this one will come in handy often I suspect), and photo 4 the higher toolpost which is supplied with the headstock riser block.
« Reply #669 on: August 21, 2016, 04:28:00 PM »
Thanks for the pictures Bill.  That ought to give you a little more room to work!
You'll have to let us know how they work out for you, and how much it affects the rigidity of your lathe.
I have a set of riser blocks for my Taig, but I have never used them.
Thanks,
« Reply #670 on: August 21, 2016, 04:45:51 PM »
Looks good so far Bill. Will be looking forward to your flywheel post.
« Reply #671 on: August 21, 2016, 10:52:36 PM »
Ready for the next big flywheel!   :cartwheel:
I have the riser blocks for my Sherline too, think that I use the headstock riser more often on the mill to give more horizontal reach than on the lathe, but comes in handy on both. The tailstock extender is most handy for getting the live center to reach in farther, especially when the QCTP is angled for some cuts. I don't use it much for the drill chuck.
« Reply #672 on: August 22, 2016, 12:31:58 AM »
Got a bit done on one of the flywheels this afternoon, though in spurts, it was still HOT in the garage today. A couple of pictures are shown below. Height was not a problem with the riser block, but as I knew already, working that much farther out from the centerline of the lathe does put more strain on the motor. Rigidity seemed ok once I got past the interrupted cuts on the periphery of the flywheel from the casting gates, etc. I played around with several toolbits...the Warner insert bits, a 1/4" ground HSS toolbit, brazed carbide, and the tangential.  Actually the tangential seemed to work the best and is easy to keep sharp which is critical. This will work but not fast. Even so it will go fster than trying to get it done at work the way things have been lately. In the pictures, I just about have the OD of the flywheel down to the 5" specified. Now working on getting the thickness faced down on one side and then will do the other side. More to come over the days ahead.
« Reply #673 on: August 22, 2016, 12:40:29 AM »
Cool Bill and a brass flywheel ohhhhhhh. That microsander can work miracles on that flywheel buddy. Good to see more progress and can you show photos of the riser blocks?   :ThumbsUp:
« Reply #674 on: August 22, 2016, 12:44:14 AM »
Go back to post 668 Don and you will see them. Actually the flywheels are bronze but the finishing should be similar to brass. Thanks for looking in my friend.
