Author Topic: Parsell & Weed Horizontal IC Engine  (Read 139317 times)
Re: Parsell & Weed Horizontal IC Engine
« Reply #225 on: February 27, 2016, 10:42:17 PM »
I could have eyeballed it and come close Zee, but the square was easier and likely a lot closer than my eyes. I didn't want the cylinder head to end up at some wonky angle however small :)
« Reply #226 on: February 27, 2016, 10:52:05 PM »
Sure enough a right nice Looking job there Bill. Nice to see some more progress........... :ThumbsUp:
Don  8)
Offline joe d
  • Montreal, Canada
« Reply #227 on: February 27, 2016, 11:27:41 PM »
Well, seems second time is the charm, Bill.   :ThumbsUp:
It certainly often is around here.....
Joe
« Reply #228 on: February 27, 2016, 11:56:55 PM »
Thanks Don.  Joe, thank goodness, I wasn't looking forward to a third try :)
Offline littlelocos
« Reply #229 on: February 28, 2016, 12:53:43 AM »
 :ThumbsUp:
« Reply #230 on: February 28, 2016, 01:00:43 AM »
Thanks Todd.  I am going to play around with some samples I sheared off of the blue tempered spring steel tomorrow and see if I can find a way to bend the stuff successfully. Will keep you posted.
« Reply #231 on: February 28, 2016, 02:31:19 AM »
Nice work Bill!
« Reply #232 on: February 28, 2016, 06:35:47 AM »
Great work on the collars, Bill! Looking good.
Enjoying your build  :popcorn:
« Reply #233 on: February 28, 2016, 09:13:17 AM »
Still following and learning  :ThumbsUp:  :ThumbsUp:  :wine1:
« Reply #234 on: February 28, 2016, 08:10:13 PM »
Hi Bill, I am still there and following your build log.
Offline Myrickman
« Reply #235 on: February 28, 2016, 10:39:03 PM »
The cylinder certainly turned out well Bill. I like how you blended the OD of the rings to the tangs. Always a bit of pucker factor when you tear into a major casting and have a bunch of hours in it...your careful persistence shows in the end product. Paul
« Reply #236 on: February 29, 2016, 12:00:07 AM »
Thanks for checking in guys. I did get all the tapping done on the collars so that was a relief too. They are done now. I did some roughing work on another pair of casting but no pictures of that to show yet. Also played around with bending the blue tempered spring steel and that went pretty well actually. I need to shear off some pieces closer to the width dimensions I need tomorrow at work so more to follow on that front as well in the next day or so.
« Reply #237 on: February 29, 2016, 12:26:07 AM »
The work on the "prototype collar " payed off,  8), great looking stuff Professor
Cletus
« Reply #238 on: February 29, 2016, 01:01:16 AM »
You know I had to comment.  ;D
« Reply #239 on: February 29, 2016, 01:09:11 AM »
Oh I was counting on it Zee...might have even planned it that way  :naughty:
