Author Topic: Parsell & Weed Horizontal IC Engine  (Read 100276 times)
Re: Parsell & Weed Horizontal IC Engine
« Reply #15 on: November 19, 2015, 01:12:43 PM »
Thanks for the links Sage, those are both beautiful engines and fine runners too!!
Offline littlelocos
« Reply #16 on: November 20, 2015, 02:25:27 AM »
Dave,
Beautiful engines!  I had not seen Steve Kahler's air cooled engine.  Thanks!
Todd.
« Reply #17 on: November 26, 2015, 09:00:26 PM »
Got a start today on the muffler. Some of the smaller parts are ideal for the Sherline equipment so that seemed like as good a starting place as any. Below are the pictures from today. Unfortunately I didn't take any of turning the angles on both the front and back of the muffler parts, but the Sherline lathe compound was used for that on both the outside of the profiles as well as the inside as shown in picture 4. Rather than riveting the two halves together, instead I threaded the back side for 1-72 and used three 1-72 SHCS's to fix the two halves together, making it easier to disassemble if ever necessary. The rest is pretty straightforward. I am excited about making the first few chips on this one!!
« Reply #18 on: November 26, 2015, 10:55:47 PM »
That make a very nice little muffler. I'm enjoying the ride, keep it coming!
« Reply #19 on: November 27, 2015, 12:01:47 AM »
Well it looks like you couldn't resist the temptation and decided to jump right in Bill.  :stickpoke: The muffler looks great bud and I'll be joining in on the ride.......... :ThumbsUp:
« Reply #20 on: November 27, 2015, 12:18:36 AM »
Thanks guys. Don, it must have been all your brass on the E&A that got me wanting to make some brass swarf  ;)
Offline joe d
  • Montreal, Canada
« Reply #21 on: November 27, 2015, 12:33:17 AM »
A good start, Bill.
I'm settling in for the show... :popcorn:
Cheers, Joe
« Reply #22 on: November 27, 2015, 01:29:36 AM »
Speaking of brass once I seen Steves Panther Pup I just had to order the casting. I have had the plans now for 3 yrs. So Stanta is bringing them to me.
« Reply #23 on: November 27, 2015, 02:03:34 AM »
I know you will do it proud Don. Will be looking forward to it!
« Reply #24 on: November 27, 2015, 05:24:11 AM »
Following along Bill.  :popcorn:
Offline Alan Haisley
  • Near Clayton, North Carolina, USA
« Reply #25 on: November 27, 2015, 05:58:38 AM »
 :popcornsmall:
Alan
Near Raleigh, NC, USA
« Reply #26 on: November 27, 2015, 07:26:55 AM »
Looks to be an interesting build  :ThumbsUp: I will be following along  :wine1:
« Reply #27 on: November 27, 2015, 03:45:47 PM »
Hey Bill
Good to see a start on the P&W; I will be pulling up a chair and following along with your build. Your projects are always interesting and fun to watch.
« Reply #28 on: November 27, 2015, 09:08:11 PM »
Thanks for looking in Vince, Alan, Roger, and Dave!  I got a bit more done today on some of the smaller parts, lath work mostly. First up was the Governor weight, just a simple cylinder of brass 3/8" dia. x 3/8" long with a .125 bore and a threaded hole for a grub screw/thumb screw for adjusting it. The three pictures below a self explanatory with the obligatory mini-mic pic :).
« Reply #29 on: November 27, 2015, 09:17:46 PM »
Next up today was the brass Mixer Body, also made from a short length of brass. This will eventually attach to the cylinder head but uses a 12-40 thread and I have neither the tap or die for that size as it isn't very common so will need to order those from MSC before I can thread the thin end of the Mixer Body (photo 1). Otherwise it is finished though. The big (inlet) end of the mixer is tapered using a 60 degree center drill as shown in photo 2. Photos 3,4 & 5 show drilling the holes for the Jet to attach to the bottom side (5-40 thread), and for the needle valve to attach to the top side (1-72 thread).
