Author Topic: Myford super 7 motor connection modification  (Read 6535 times)
« on: August 18, 2012, 09:08:56 PM »
I just purchaseed a Myford Super 7 lathe and it came with 220volt motor. Well were I am putting the lathe this is to much trouble and if I wanted to move it I would have to do it all over again. So I decided to reconnect the motor and add more leads to it. This would involve taking the motor apart and tapping into the windings to add new leads. Anyway this is my documentation of that task to make it a dual voltage motor and connect it for 120 volts.
First the lathe
a look at the motor
opening up the motor you can see the starting winding switch and the lead connection.
location of the starting winding center tap, which is the smaller winding closest to the rotor and there are four coils, making this motor 1800 rpm
 at 60 Hz. You have to dig around and count two coil from the lead connect to the starting winding switch and you should see a jumper cross over to the next coil, this should be the center tap.
next I clean the connect up and connect a 12vdc power supply to the center tap and one of the main start winding leads and do a magnet test, just to see if two coils pulls my screwdriver toward them each individually. When I do the run winding I will do the same.
a look at the starting winding switch and you see my pointer showing where one of the new start winding leads will connect. I will label this wire No.5.
The running winding were a little harder to find the mid tap, but I located it on the opposite side of the stator and not the side the leads were located. This ceated more problems because now I had to drill two hole to the opposite side of the stator to get the leads to the proper side.
The centert tap run winding lead exposed.
Doing my center tap test with 12vdc and magnetic test, do this with both the exsisting run wind leads.
Breaking the connection ready for new leads. At this time I used my meter to check continutity from one of the cut leads to the existing leads, the first lead that reads I label No.1 and the other end No.2, I do the same with the reminding lead , but I label the last existing lead No.4 and the new lead No.3. These are standard US motor numbers for single phase motors. I will show a drawing of the connection at the end of the thread.
I will continue on a new reply.
Re: Myford super 7 motor connection modification
« Reply #1 on: August 18, 2012, 09:10:32 PM »
Now to continue with the process I drill the holes through the stator for the addition of my new run winding leads.
Then I went to my local motor shop and got motor lead, glass sleeving and lacing twine.
Silver soldering the new leads. You can soft solder if you don't have Silver Solder.
Lacing the back side of the motor, placing the leads through the drilled holes.
Preparing for the connection of all the leads.
Just a shot of my lacing needle.
Making the eyes for connection to the terminal.
Just showing the loop after it has been soldered.
Metal number tags I picked up at the motor shop.
This is the final shot of the motor after numbering the leads, I put marker to show some of the lead numbers, but I haven't finished the drawing for the motor connection yet and will post that tomorrow. I will have the terminal numbers for the motor connection and lead color, so anyone wanting to modify there motor can do it with ease.
 The contactor that came with the lathe also has a 220Volt coil. I will be
Changing the contactor to 120volt coil contactor as well. The starting capacitor is a little small and provides less torque because of the new connection, so a large capacitor can be installed if not satisfied with the torque at start up. Twice the value should be enough.
« Reply #2 on: August 18, 2012, 11:34:48 PM »
OHHHHHH....electron plumbing.....I stay away from electron plumbing......we don't get along!
 :Lol:
Braver man than I Don!   I'd a dropped a new motor in.....
« Reply #3 on: August 18, 2012, 11:44:55 PM »
Nice lathe Don!
« Reply #4 on: August 19, 2012, 08:05:31 PM »
As promised Here is the motor connection drawing.
