I think you are starting to like the "Commiefornia Cool Aid" way too much
How Beautiful!!! This design comprises an excellent mix of art, mechanical design and excellent craftsmanship. Though the design its self is complex, it seems so simple. I think it's all about the presentation. It's much more than an animated humming bird, the artist has given us a portal into the beauty of nature. Also, I don't think it's about gears, though they somehow seem to bridge the gap between mechanics and art.Whose work is this? Who ever you are, I commend you on your excellent achievement.Also, Stan, where are the plans available, I'm all in!maury
To avoid having to crank a handle maybe a small steam or ic engine would be fun.
I've not seen anyone try to build Colibri out of metal yet. I think it would work, but there are two things I would be cautious of. One is weight. Metal is going to be substantially heavier than wood, so the sculpture's counterweight will likely need to be much larger than shown. The added weight may also add extra stress on the cam mechanisms, which may or may not be a problem. The second concern I'd have is galling. It would be a good idea to make mating/sliding/rotating parts out of dissimilar materials. As you know, aluminum doesn't tend to slide very well on aluminum. If you decide to make one out of out metal, you may want to tighten up the tolerances between mating parts as well. Most of the parts were designed to be a little loose, to allow the wood to swell a bit with changes in humidity.I imagine Colibri made with a combination of materials could look pretty cool. I've wondered what it would look like to make the frame, base, and mechanisms out of clear acrylic or PC, and making the hummingbird out of aluminum and nylon. Haha, if only I had more time to try these things! Anyway, I hope I was able to answer your questions.
