Author Topic: My Ordinary Little Hit & Miss Engine  (Read 26939 times)
Offline Myrickman
Re: My Ordinary Little Hit & Miss Engine
« Reply #75 on: October 10, 2015, 10:38:04 PM »
A most excellent little engine Rudy! Picked up a lot of good tips on your build. Will be that much sweeter when you get the governer installed. Paul
« Reply #76 on: October 11, 2015, 12:01:44 AM »
Very nice Rudy!
Fun to see something come together so quickly; unlike my projects which seem to go on for years.
« Reply #77 on: October 11, 2015, 01:04:05 AM »
Awesome results Rudy she's quiet a runner................  :ThumbsUp:
« Reply #78 on: October 11, 2015, 01:10:54 AM »
Most impressive Rudy. Quiet and very smooth too. Looking forward to seeing it in hit and miss mode. Well done!!!
Offline cfellows
« Reply #79 on: October 11, 2015, 05:26:45 AM »
Excellent!  Good looking and a great runner.
Chuck
« Reply #80 on: October 11, 2015, 06:43:11 AM »
Hi Rudy, it is running like hell. Waiting for the govenor. Well done.
« Reply #81 on: October 11, 2015, 07:41:44 AM »
Excellent  :praise2:  :praise2: That's running a few 1000 rpm  :wine1:
« Reply #82 on: October 11, 2015, 08:35:53 AM »
 8) Nice.
Offline sbwhart
  • Live Long and Prosper
« Reply #83 on: October 11, 2015, 10:52:53 AM »
Great Stuff   :cartwheel:
Well done
Stew
Offline rudydubya
  • Western Arkansas USA
« Reply #84 on: October 12, 2015, 03:46:40 AM »
Everyone, thank you all for your kind remarks.  I'll try to hurry and get to the finish.
But first, the hit & miss governor.  The governor is a common centrifugal hit & miss type with a sliding bobbin (in red), a lockout lever (green), and a fixed stopblock (blue) on the pushrod (orange).  A small torsion spring (black) made from 0.010" music wire helps clear the lever from the stopblock.  The lever blade is arched up and away from the lever body to clear the cam gear screw and reach the bobbin.
The governor weights (orange) are attached to arms (blue) that pivot on a carrier (green) attached to the flywheel.  The governor springs (yellow) are hooked over screws in the weights.
The most interesting part may be the lever.  It's made from a single piece of brass with a short length of 1/16" brass rod Loctited in as a spring stop.
I made it with the aid of some fixtures to hold it for the curves and pockets.
Here is the lever after I had smoothed it with a file and secured the pin with Loctite...
Continued...
Rudy
« Last Edit: July 19, 2017, 09:53:33 PM by rudydubya »
Offline rudydubya
« Reply #85 on: October 12, 2015, 04:00:27 AM »
Continuing with the governor parts, here's the combined lever mount/pivot and pushrod guide.  To keep the lever short, I put the mount closer to the cam and removed the original guide.  The holes for the old guide are are still there in the frame, and I thought about using the holes to mount some kind of lockout switch for the ignition while the engine was coasting, but the thought faded.  I don't mind a few wasted sparks.
The governor-weight pivot arms, made from brass ...
And then the pivot carrier, made from aluminum.  After it was made, I set up the flywheel on my rotary table to drill mounting holes for it.
After I had drilled for the carrier, I took the opportunity to clean up some of the scars on the flywheel spokes.  I think next time I'll do the flywheel webs on the mill and rotary table instead of the lathe.
The governor weights are 3/16" diameter brass, 1/4" long and drilled and tapped through for 0-80 studs and screws.
The pushrod stopblock is just a piece of 3/16" diameter brass drilled through for the pushrod, with a tapped hole through one side for a 0-80 setscrew.
The governor springs are 0.010" music wire close-wound on a 3/32" mandrel (I made them about 0.70" long, but had to shorten them to fit between the weights).
And everything put together on the flywheel.
Continued...
Rudy
« Last Edit: July 19, 2017, 09:59:46 PM by rudydubya »
Offline rudydubya
« Reply #86 on: October 12, 2015, 04:10:29 AM »
A few more additions before I get to the good part.
While I was testing the engine with the governor, I found that I didn't have enough adjustment range to set the carburetor properly for good hit & miss operation.  I made a simple replacement carburetor using a tapered 0-80 screw for a needle.
I threaded a piece of brass rod and screwed a long 0-80 screw through it.  I turned the taper on the screw with very light cuts while running the lathe backwards.  The threaded needle also allowed me to use internal threads on the carburetor body, easier to make than my previous version.
Also new is a finished base and ignition box for the engine.  The engine and base top can be lifted off as a unit to access the ignition module and batteries.  The plug wire and ground are routed from inside the box through notches to the knurled connectors outside.  The Hall sensor connectors are tucked inside the box when it's closed.
The finished product.  I haven't decided if I'll paint it or not.
I'll post a video of it running in hit & miss mode next post.
Rudy
« Last Edit: July 19, 2017, 10:05:37 PM by rudydubya »
Offline rudydubya
« Reply #87 on: October 12, 2015, 04:31:44 AM »
And here it is running in hit & miss mode.  Hope you enjoy it.
[youtube1]https://youtu.be/obseeCEDECU[/youtube1]
Thanks all for following along.
Rudy
« Last Edit: July 13, 2017, 09:19:20 PM by rudydubya »
« Reply #88 on: October 12, 2015, 04:48:39 AM »
Hi Rudy, excellent. A very smooth runner. I enjoy it to follow the motion.
« Reply #89 on: October 12, 2015, 05:58:33 AM »
That is a most amazing little engine Rudy. Those little, tiny, parts are way beyond me I think.
And it runs so much like the full size engines!!
