Author Topic: Adapting "Firefly 46" as an opposed twin.  (Read 2064 times)
Offline fatboyfinn
  • Jr. member
« on: September 11, 2015, 01:28:41 PM »
Having finished building a Firefly 46 - brilliant design and drawings Mr Whittacker.
I have always had a penchant to put together a flat twin. I thought the crankcase and
cylinder arrangements would suit. Advice on crankshaft design would be appreciated.
A fabricated crank is my first choice with an aft bearing in the back plate. The carb turned
through 90° and cylinders
Best Wishes Andy
Online Jasonb
Re: Adapting "Firefly 46" as an opposed twin.
« Reply #1 on: September 11, 2015, 01:33:08 PM »
Should work OK, I would go with a 180degree crank, I did similar (solid) when I made an opposed twin from a Nemett Jaguar. Crankcase would need stretching a bit so you can stagger the cylinders.
Yes they are a good set of drawings, I enjoyed making mine.
« Reply #2 on: September 11, 2015, 01:34:28 PM »
Nice looking engine Andy, and welcome to MEM. It would help greatly if you post and introduction and tell us a bit about yourself and your modeling interests in the "Introduce Yourself" section.
