Author Topic: Lady Godiva Rides Again - Roy Ozouf's Coventry Engine  (Read 38521 times)
Re: Lady Godiva Rides Again - Roy Ozouf's Coventry Engine
« Reply #90 on: February 19, 2016, 03:10:18 AM »
That's a fine update Stan!  Thanks for all the pictures & explanations.
I had to go back and watch it run again to see all the fiddly parts moving and I'm still not sure how they're all connected. Do you have a few more fiddly parts to go?  I didn't see the thing that connects the valve rod rocker to the yoke/link gizmo.  Have you showed us that part yet?
Just fascinating!
Offline sshire
    • LS Editions
« Reply #91 on: February 19, 2016, 03:22:38 PM »
To be honest, I didn’t completely understand the valve motion and the part interactions untilI assembled the engine.
I realized I had no pictures of the die block which connects the rocker arm to the link.
The only thing to do was to boot the Mac into Windows and fire up Inventor.
Hope this helps
The die block
The die block inserted into the rocker arm.
A 2-56 nut holds it together and the die block is free to pivot as it travels within the link slot
The complete sub-assembly
Best,
Stan
« Reply #92 on: February 19, 2016, 05:00:44 PM »
Thanks Stan, that helps a lot!  Even I could follow that description!  Loved the renderings :)
This is really a fascinating (maybe even overly complex) set of motions to move the valve.  Was this a real engine?  It is just amazing to watch.
Sorry, I didn't mean to call you out on the one part you didn't show. I just figured that I'd missed it, or that it was still to come!
Thanks for the detailed explanation Stan!
Superb build log, as always!
Offline sshire
    • LS Editions
« Reply #93 on: March 20, 2016, 09:07:42 PM »
Lady Godiva Rides Again - Episode 8
Roy Ozouf’s Coventry Engine
Control Tower
The drawings show an air control valve stand. They also say, “see text.”
Roy must have decided that if you’ve gotten this far, you don’t need no stinkin’ text as it does not exist. It is pretty straightforward so off I went. I did make some changes to thread sizes, etc. based on the taps, dies and brass stock I had on hand.
The drawing shows the body turned from a 1” diameter brass round. Since the only thing that is 1” is the ⅛” base flange, it seemed like a lot of brass was going to be converted to chips. I decided to make the body in two parts: The flange and the upper body.
A .625 brass round was turned to shape.
Then. reversed, drilled and tapped.
Next, two bosses to be drilled and tapped ¼-40. These will be soldered into the body.
With those completed.the body was moved to the mill, spot faced and two .25 holes were drilled 90º apart.
A dry fit.
Next, the plug. This was turned and parted off.
Then, two intersecting holes were drilled 90º apart to align with the holes in the body.
Rummaging through the brass box, I located a cutoff that had the correct dimension for the base flange. Turned per the drawing.
Moved to the mill for a bolt hole circle for mounting bolts.
The shaft nut was turned from a brass hex, shaped and threaded.
A family shot.
One more part for the valve. The drawing has this machined from solid. I wasn’t thrilled with the look of the part. My version follows.
Starting with a 1” brass round.
I need a .75” bore. Step drilled up to a Silver and Deming bit slightly under .75.
Then bored to diameter.
I wanted to maintain a .125 wall thickness. In order to measure accurately, a ball was installed on the micrometer. This adds .200 to the measurement.
Then the wall could be measured. So, .3251-.200=.1251. Close ‘enuf.
Moving the part to the mill, 4 holes were drilled around the perimeter. 90º apart.
A form tool and files shaped the edge.
Another brass round, center drilled, 4 holes on the perimeter and the center hole filed square.
Then 4 precisely equal length brass rods.
So, we end up with this collection of parts.
When assembled, make a hand wheel for the valve.
They will be soldered tomorrow followed by filling, polishing, etc.
The body and base flange needed to be soldered. I had been thinking about using Tix solder. It has a low liquidus temperature (275º F/135ºC) and a tensile strength of 4000 PSI. After cleaning all of the parts and applying Tix flux, I cut small pieces of the solder and put the assembly on a hotplate. Two minutes later, the solder melted and flowed beautifully through all of the joints. No torches, no melted brass.
Paint is next, then the base. Stay tuned.
Best,
Stan
« Reply #94 on: March 20, 2016, 09:13:26 PM »
Nice episode Stan.
You mentioned stepping up in drill sizes. Having just had another bad time with big drills...in what increments do you step?
Offline sshire
    • LS Editions
« Reply #95 on: March 20, 2016, 09:17:42 PM »
Zee
I did ¼, 3/8, ½, 5/8 and .73.
Best,
Stan
« Reply #96 on: March 20, 2016, 09:19:01 PM »
Nice work on that Stan. It turned out beautifully. I like that little handwheel also. Good to see an update on this build.
« Reply #97 on: March 20, 2016, 09:29:40 PM »
Nice results Stan and the handwheel turned out great. Anxious to see it after sliver soldering. If you remember when I made my handle I used five parts to build it up also.
« Reply #98 on: March 21, 2016, 01:17:05 AM »
Nice update Stan!
Good to see you back at it!
« Reply #99 on: March 21, 2016, 05:15:58 AM »
Very nice work Stan!
« Reply #100 on: March 21, 2016, 05:24:26 AM »
Hi Stan, nice update and some interesting parts. I like the soldering
« Last Edit: March 21, 2016, 08:18:55 PM by fumopuc »
« Reply #101 on: March 21, 2016, 10:41:28 AM »
Vern, beautiful fab work. I really like the hot plate method  :ThumbsUp: :ThumbsUp:. I was thinking though, you really ought to turn the heat up and ditch the sweater 'fore you get hung up in something or catch on fire  :lolb:
Cletus
Offline sshire
    • LS Editions
« Reply #102 on: March 21, 2016, 11:11:06 AM »
Thanks, guys. Much appreciated.
Hey, Cletus! That's my LL Bean, Machinist Model,  lucky shop sweater. The shop stays at 70°F year round but if I don't wear the shop sweater, I muck up parts. The sleeves push up nicely when I'm at the lathe.
Best,
Stan
« Reply #103 on: March 21, 2016, 12:10:44 PM »
Good tip on the Tix flux/solder.  I'm going hunting for some.  :ThumbsUp:
Nice work on the valve too.
Offline sshire
    • LS Editions
« Reply #104 on: March 21, 2016, 12:24:02 PM »
Best,
Stan
