Author Topic: Lady Godiva Rides Again - Roy Ozouf's Coventry Engine  (Read 38641 times)
Offline philjoe5
Re: Lady Godiva Rides Again - Roy Ozouf's Coventry Engine
« Reply #75 on: February 10, 2016, 08:58:49 PM »
Stan,
Beautiful work on an interesting engine, congratulations :ThumbsUp:
Cheers,
Phil
« Reply #76 on: February 10, 2016, 10:13:02 PM »
 :ThumbsUp:
I'm watching and enjoying my  :popcorn:
« Reply #77 on: February 11, 2016, 01:43:01 AM »
Very nice work my friend!
« Reply #78 on: February 11, 2016, 06:27:16 AM »
Enjoying your write-ups, Stan, as always!
Very nice runner too!
Offline sshire
    • LS Editions
« Reply #79 on: February 12, 2016, 01:44:44 AM »
Lady Godiva Rides Again - Episode 6
Roy Ozouf’s Coventry Engine
Crosshead
The crosshead began with brass flatbar and round stock.
Everything was squared, drilled and fitted for silver soldering.
A form tool was shaped from ground O-1 tool steel and oil-hardened.
The crosshead top and bottom were turned with the form tool.
The corners of the body were turned round.
After parting off, the part was moved to the mill and indicated vertically.
Then, cut in half.
After attaching both halves with screws, the part was drilled and reamed.
The Eccentric
More bronze, turned and parted.
Centered on the mill with the Blake center point.
Then, the X axis was moved .109”, drilled and reamed.
The Eccentric Strap
Laid out on .25” brass plate
Locating pin and screws for the rotary table.
Some touchup and bolt recesses milled
Then, cut in half.
Cylinder passages and other holemaking.
The port block and steam chest aligned
Then clamped in position on the cylinder for drilling and tapping the attachment holes.
I decided to drill the air passages through the cylinder and port block. The drawings suggest spotting the port block in position, removing it and then drilling. This seemed like too much possibility for error. This way, I know that the passages are aligned perfectly.
Opening the admission/exhaust port.
Now for the bottom side passages
Tapping the holes for the piston rod gland retaining screws.
The Ministry of Fiddly Bits returns in the next episode.
Thanks for tuning in.
Best,
Stan
« Reply #80 on: February 12, 2016, 02:00:44 AM »
Beautiful work and documentation Stan.  Can't wait to see if this sucker runs   :lolb:  Yeah I know its a retro log :)
« Reply #81 on: February 12, 2016, 02:02:54 AM »
Awesome work and photos Stan. You are the man buddy........ :praise2:
don
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #82 on: February 12, 2016, 03:00:34 AM »
Great work Stan! :ThumbsUp:
Thanks for sharing  :cheers:
« Reply #83 on: February 12, 2016, 11:08:49 AM »
Good episode Stan. Looking forward to the Fiddly Bits, minister.
Offline sshire
    • LS Editions
« Reply #84 on: February 19, 2016, 12:49:25 AM »
Lady Godiva Rides Again - Episode 7
Fiddly Bits
The valve action has all manner of small parts which move in mysterious ways.
The rocker bracket was laid out with a print of the drawing.
After roughing it out with a jeweler’s saw, much sanding and filing followed. Here, the Foredom Flex shaft tool in it’s holder.
Then to Oliver
A tube was turned down at one end to fit in the bracket hole for silver soldering.
Next is the rocker shaft. Again two parts to be silver soldered. First, the rotary table to round the ends.
The valve rod end first has a slot milled with a center-cutting end mill (.093)
Then to a square collet to round, drill and tap the other end.
The link, is another built-up part. It moves up and down on parallel rods which pass through the link guides.
Starting with a piece of brass flat bar, it was face milled to thickness.
Then, small recesses were milled to locate the guides for soldering.
Drilling and rounding.
And, slotted.
A bit of filing finished the link.
Starting with .25” brass square bar, the top was rounded.
Positioned for soldering
Next, the guide rods. To ensure that they were the same length, I used the Cletus-built,close-enuf,  bolt action tailstock stop. Amazing!  It worked so well and was so much fun that, I couldn’t stop at the required two rods.
Then the tiny, threaded brackets for the guide rods. First, milled, then cut.
Two extra (just in case I did a Bozo op)
The brackets, guide rods and link, screwed to the side plate.
Drilling the steam chest, gland mount.
In position with working hardware.
I though I’d start with a large chunk of brass for the valve as it’s easier to hold.
Milled and cut off.
And, in position
Now, onto the rocker arm, laid out and screwed to the rotary table.
Cranking the table around to the layout lines
And the, addressing the sides
The arm had a turned boss. I turned a tiny faceplate, screwed the arm at center and melted some Crystalbond to hold the part.
Beginning the assembly. Now it may be easier to see how the valve motion works. The part not shown is a “die block” with floats on the rocker arm and travels in the link slot.
Next, smoothing out the side plates and the flywheel.
Best,
Stan
« Reply #85 on: February 19, 2016, 12:59:48 AM »
Man, you hit the fiddly bit jackpot with this update Stan. Nice work though all the way around.
« Reply #86 on: February 19, 2016, 01:11:53 AM »
Awesome Stan! I just love all the setups. You sure hot the jack pot this round......... :ThumbsUp:
« Reply #87 on: February 19, 2016, 01:25:37 AM »
I'm amazed at all those little tiny parts Stan; you are going after it like an old pro!
Great pictures, machine work, fabrication, set ups, and wonderful results.
I haven't had a chance to use my Close-enuf,  bolt action tailstock stop yet; but I'm looking forward to be being able to put it to good use.
Nice work!
« Reply #88 on: February 19, 2016, 01:37:08 AM »
Vern, you're spinning that RT like Wolfman Jack did a turntable. All around great craftsmanship. It is a joy to use a fine handmade tool, now isn't it  :lolb:
Cletus
« Reply #89 on: February 19, 2016, 01:53:23 AM »
More teeny, tiny, little parts. :insane:   Amazing how ya'll make those. The biggie for me on this page is the...
Bolt Action Stock Stop Cleat(us)  Never seen the likes of that before and it's now part of my gonna do it list.
