You need not rely on the pump check. For testing you can put a shut-off valve in the line...Pete
Just a thought - have you checked to make sure there is no leak at the gauge end of the tubing, or in the union from the pump to the tubing?
Kim, you are a lot better off than you were yesterday for sure. Still puzzling though why the original seat didn't work better. Maybe the spring was the critical component in the new design.Bill
Thanks Gerald,Well, in practice it should be running around 30 lbs, which would be right in the center of the gauge. maybe I should have gotten a bigger gauge for my testing. I was hoping that I could get by with one, but maybe that was a silly place to economize. Would you generally suggest a separate gauge to use for testing? One with twice the range of the one you intend to use in practice?Thanks for the advice. As you can likely tell, I'm quite the novice at this!Kim
