Author Topic: Steam Tractor 3/4" (Rudy K)  (Read 246789 times)
« Reply #450 on: September 06, 2016, 08:52:35 PM »
I believe Jason is correct I hadn't noticed it. The brass should cut clean and at a high speed.
« Reply #451 on: September 07, 2016, 03:28:58 AM »
Thanks Pete, Mal, Don & Jason!  I do appreciate the encouragement and the suggestions!
Jason, that's a very interesting idea.  It should be easy to test, but I'm not sure how to sharpen the cutter.  Its just tiny, and anything I do, I fear, will only make it worse!  I tried running a diamond stone over the cutting surfaces, but I just don't think I can make it better free-hand.  I'll have to figure out some way to jig something up to sharpen.
« Reply #452 on: September 07, 2016, 05:17:24 AM »
Kim looking at the cutter in the picture, the cutting edge looks rounded over where it should be flat.
« Reply #453 on: September 26, 2016, 12:05:38 AM »
Hi Don, thanks for the input.  I think you and Jason are right, and I’ve tried to address this, as  you’ll see below…
Also, it seems that the site was down for most of yesterday. I wrote this update but was unable to upload it till today.  Thanks to whoever got the site back up and running again!
It’s been a few weeks since I’ve posted an update, mainly because I don’t have much progress to show.  I’ve run into several complications, most of them being self-inflicted.
I decided it was silly to go with the big gears first, so I moved to the smaller ones, and am currently aiming at the 32 tooth gear.
My first set back was this: I struggled with one of my gear cutter blanks.  It turned poorly – kept grabbing and tearing.  It just turned really bad.  This is W-1 tool steel, and I’ve never had any problem with it before. I don’t have a clue what was going on.  I tried annealing it and thought that would help, but it didn’t. I was just pushing through with it, but then, my button tool broke, like so:
With that, I scrapped that button, decided to make one with a 1/8” pin (as opposed to the 1/16”).  So I made a new tool, and a new button.  Heat treated it and here it is, ready to go:
That whole episode cost last weekend.  This weekend I used a new cutter blank with the new tool and it worked dramatically better.  I’m thinking that I just didn’t anneal the blank well, otherwise it should have worked fine.  And I don’t know why I needed to anneal it in the first place.  Can Tool steel work harden?
Anyway, I very carefully created my 32 tooth, 48 DP gear cutter.  I made this one with much more attention to the spacing than I did the others.  I was careful with them, but I was that much MORE careful this time around.  And I think it helped.
Another thing that probably helped was that I sharpened the cutting face to remove that somewhat rounded edge.  I did it using my HH Advanced Grinder Rest, like so:
Then I made a blank for the 32 tooth gear (0.708” dia) and gave it a spin.  No pictures, since it looks just like all the others.   But… as I was getting to the last few teeth, I started to realize that I was running out of space on the gear blank!  The teeth wouldn’t all fit.  And I found that I hadn’t tightened the collet holding the gear blank.  :facepalm:  I clearly remember reading someone having this issue a week or two ago, and thinking to myself “I’ve done that before!  That’s why I check my collets CAREFULY every time before I start a cut.”   :facepalm2: :Doh: Guess I’m not as careful as I thought, and now I’ve re-learned that lesson!  (probably not for the last time).  Anyway, my 32 tooth gear came out at 31.5 teeth.  I went ahead and cut the last ½ tooth twice so that it was REALLY noticeable.  Because it’s not even a useful 31 tooth gear – it would likely have very uneven tooth spacing.
But at least the teeth are coming out with a better profile.  I’ll keep working on getting them even better!
OK, so still all the gears to go. Someday, I’ll make a keeper and start making forward progress.  Till then, I guess it’s just more practice gears!
Thanks,
« Last Edit: July 08, 2017, 06:35:26 PM by Kim »
« Reply #454 on: September 26, 2016, 12:35:11 AM »
It's still progress Kim. Maybe frustrating at times but still progress. I am learning a lot from your posts too!!
« Reply #455 on: September 26, 2016, 02:39:03 AM »
Paying attention to the detail on the cutter made a huge difference. It's very plain to see! That cutter is no bulldozing the gear material now.
You've got it on the run now!!
« Reply #456 on: September 26, 2016, 05:42:33 AM »
Thanks Bill and Pete!
I'm getting there!  But as I keep telling my wife, what's the fun if it works the first time?  That means I'm not really learning anything new, right?  (and I keep telling myself that too :))
I'll whip these puppies into shape before too long!  :Lol:
« Reply #457 on: September 26, 2016, 07:57:17 AM »
Well Kim, don't bang your head against the wall too much :wallbang:
'cause you'll get a headache :hammerbash:
and also go bald.  :old:
« Reply #458 on: September 27, 2016, 12:10:48 AM »
Kim don't beat yourself up buddy, it's all in the learning. Your making headway even though you have mishaps because your teaching yourself. The last gear looks a whole lot better just a slip of the collet. The buttons have to be annealed because they will snap just like the one you did, so anneal it well. The one thing I want to point out is that you are trying and that's a plus for you. You will not regret your efforts.
« Reply #459 on: September 27, 2016, 03:42:34 AM »
Thanks Pete and Don,
I really do appreciate the encouragement :D
I'm really not feeling that beaten down about it.  As you said Don, I'm seeing a lot of improvement in my gears, and I'm confident I'll get usable gears.  I mean, look how far I've come?  Last year at this time I was learning to do rivets and having a time with my soldering.  Following that I did a bunch of sheet metal work, all new to me.  And now I'm doing gears!  I mean, how exciting is that?  :)  All these new things were the motivation for me to take on this project in the first place (That, and the fact that it's so cool!)  And I'm not sorry I tackled it in the slightest.
Clearly, I'm not an expert at any of these areas. But I'm having fun, learning a lot, and getting better - thanks in large part to your help, and everyone's help on this wonderful forum.
Thank you!
Offline Dave Sohlstrom
« Reply #460 on: September 27, 2016, 04:17:37 AM »
Are you a member of the Portland Model Engineers club. They meet in various locations on the second Sat of the month.
Offline joe d
  • Montreal, Canada
« Reply #461 on: September 27, 2016, 03:02:06 PM »
Things are looking good!
If you ever figure out a use for it, I've got a 79 & 1/2 tooth gear left over from my Minnie....
Joe
« Reply #462 on: September 27, 2016, 07:18:26 PM »
Kim, I haven't said much, but,  I have been  :popcorn::DrinkPint:, and following along.  I've only cut one set of gears and one test gear,  which all seemed to work out well.  I attribute this to the dividing plates I added to my RT.  Are plates available for yours?  I applaud you for doing it by the "degree setting,  don't know if I could  :shrug:
Cletus
« Reply #463 on: September 28, 2016, 06:16:40 AM »
Hi Dave,
Yes, I'm a member of PME, and even come to some of the meetings - though I haven't been in a while since its hard to find the time.  There's even a meeting a week from Saturday isn't there?  It's not too far from my house so I might try to show up.  Do you attend the meetings on a regular basis?
Though I like the idea of meeting with people face to face, with the way my world is right now, I find it difficult to set aside specific time for a meeting.  It takes time away from my family on a Saturday, which is one of the few days I get to see them.  But I still like to try :)
The forum tends to fit my topsy-turvy schedule more easily, since its here when I have time.
Joe,
We can put your 79.5 tooth gear with my 31.5 gear and we'd be set!  Something good would be bound to come out of that!  :Lol:
Hi Cletus,
Thanks for looking in on me!  Actually, using the RT and dividing by degrees hasn't been a problem for me (yet... knock-on-wood).  It's been getting the gear cutter made well, made sharp, and centered on the blank, and a dozen other little niggly things.  I think I've tripped on them all, and found that indeed, what people tell you is important in making gears, is in fact, quite important! :)
Thanks,
« Reply #464 on: October 09, 2016, 02:19:19 AM »
At my last update, I'd just made a splendid 31.5 tooth gear.
This update, I will show you the creation of the 32 tooth version!
I'm trying to make each gear better.  So this time around - in addition to remembering to tighten the collet  :embarassed: I took some extra pains to make sure everything was lined up properly.
First, I re-checked my RT to make sure that it was going around in circles without any run-out (or atleast minimal run-out).
Second, I tried a different method to center the cutter.  Before, I was lining up the bottom of the cutter with the top of the gear blank, then dropping the cutter 1/2 the width of the cutter+gear blank.  This should work perfectly, but I feel that the teeth have been coming out slanted one way or the other, so I decided to try something else. This time I set the cutter to center height by lining up one of the teeth with a center that I'd put in the RT collet, like so:
And third, I made a rod, 3” long, uniform diameter (turned between centers on my later) and used this to more accurately adjust the position of the tail stock.  Before I was lining it up by eye.  This way, of course, was much better.  I was able to accurately position the tail stock, and not move it to put the mandrel with the gear blank in place.
OK, that’s all that I did different, and the next steps were the same.  But I took pictures of them anyway.  ;) The blank set on the mandrel, all set for cutting:
And here we are, 32 carefully spaced cuts later:
And after a little clean up (I need to do a bit more I can see):
I’m quite pleased with this gear!  And it makes me feel that I’m going to have to re-do all the others, which I kind-of assumed I would anyway, but seeing this makes it quite clear, even to me!
But now I’m one down, and eight (or so) to go!
Thanks for your help and support,
« Last Edit: July 08, 2017, 06:36:06 PM by Kim »
