Author Topic: Steam Tractor 3/4" (Rudy K)  (Read 247473 times)
Offline Johnmcc69
  • Erie Pa., USA
Re: Steam Tractor 3/4" (Rudy K)
« Reply #390 on: July 10, 2016, 03:26:50 AM »
That's some really fantastic work Kim! Your setups are very effective.
« Reply #391 on: July 10, 2016, 04:52:03 AM »
Thank you Bill and John, I appreciate the encouraging words :)
Offline mal webber
  • Wales UK
« Reply #392 on: July 10, 2016, 10:45:01 AM »
Hi Kim, just caught up with your progress looking really nice there ,nice metal working.
Mal
« Reply #393 on: July 11, 2016, 06:13:57 AM »
Thanks Mal!
« Reply #394 on: July 11, 2016, 09:36:33 AM »
Very nice sheet metal work  :praise2:  :praise2:
« Reply #395 on: July 11, 2016, 11:59:58 AM »
Beautiful metal work Kim. When I made mine I didn't add all the rivets. What a difference that makes.
« Reply #396 on: July 11, 2016, 04:18:29 PM »
Thanks Roger and George,
So much of this build is new skills for me.  The sheet metal fab, the riveting, etc.  It's far from perfect but getting better!  And I keep remembering that this is my practice engine, and the NEXT one will be even better!
« Reply #397 on: July 11, 2016, 09:10:51 PM »
Just checking in Kim from out of town and your metal work is outstanding buddy. Those rivets sure set it off............ :ThumbsUp:
« Reply #398 on: July 16, 2016, 11:08:52 PM »
Thanks for following along with me Don!
Today I had a short amount of time in the shop. I was able to finish up the Fuel Bunker Insides and start working on the Motion Support Plate.
Several weeks (months?) back I had cut & shaped the sheet metal for the Fuel Bunker Insides.  So all I had to do was to form them and drill the mounting hole.
Here’s a series of shots showing the forming of the Fuel Bunker Insides.  We start with the part set up in in the cheap-o brake, prior to bending.
Here we are post-bend.
The one in back is completed, the one in front is going to be up next!
Then over to the mill to drill and tap 2-56 holes for attaching.
Here they are after some clean-up, ready to be added to the assembly.
And finally, attached to the insides of the fuel bunkers!  The cutouts you see on the inside are for some of the piping that will be added later.
With that finished, I started on the Motion Support Plate; a little channel bracket that is used to hold the far end of the cross head guides.  It will be riveted to the top of the horn plates.
First I marked it up:
Then cut it out and file/sand to shape.  Then forming.  I chose to form the channel before I did the cut-out, thinking that the bend would be more uniform that way.  Here I’ve just bent the second side of the channel. Bending these little 1/8” lips isn’t as easy as you’d think. It’s hard to bend such a such short little lip.  Also, you can see, I had to use a length of ˝” square 1018 steel to form the second bend – the official break is amost 2” wide, and I’ve only got 7/8” between the two bends in the channel.
After forming the channel, I nibbled out one end and shaped it with files.  The drawings call for those ˝” extensions to be flat, with no support.  But I have picked up from other builds that the cross head guide is poorly supported with the default design.  So I chose to add some angled pieces there to provide some additional support for the cross head guide.  Hopefully this will help address that problem.
This is where the Motion Support Plate will be attached.  I didn’t have time to do that today, so that’ll be where I pick up next time.
Thanks for looking in!
« Last Edit: July 08, 2017, 06:23:28 PM by Kim »
Offline metalmad
« Reply #399 on: July 17, 2016, 12:09:55 AM »
Hi Kim
Looking Really good there Buddy
« Reply #400 on: July 17, 2016, 12:13:12 AM »
Great progress!    :popcorn:
« Reply #401 on: July 17, 2016, 12:45:54 AM »
Looks like a lot of progress to me Kim, and nicely done too!!
« Reply #402 on: July 17, 2016, 01:38:14 AM »
Great progress Kim!
The latest parts look very nice.
« Reply #403 on: July 17, 2016, 01:54:36 AM »
Following with great interest, Kim. I'm very interested in TEs, though I likely won't get a chance to build one.
On those short leg bends; we used to bend 'em long then mill them down.....
« Reply #404 on: July 17, 2016, 03:04:58 AM »
Wow. I've missed a lot. Sorry to have been out of the loop.
Nice progress and excellent work. Rivets look great!
