Author Topic: Steam Tractor 3/4" (Rudy K)  (Read 245945 times)
Re: Steam Tractor 3/4" (Rudy K)
« Reply #1200 on: September 30, 2018, 04:21:31 PM »
And for things that get hot, (like the boiler casing), I'm wondering if I need special paints?  Or maybe it won't get THAT hot.  Or maybe I really won't run it that much :)
Perhaps it already exists but I wouldn't mind seeing a thread on paints, types, uses, recommendations, etc. A lot of people have that knowledge that must be shared! Large subject I'm sure. Maybe start out with Kim's question regarding heat.
An excellent idea, Zee!!  I haven't looked at paints in that regard for about 30 years now and I'm probably way behind in what's available these days...
« Reply #1201 on: September 30, 2018, 04:25:19 PM »
Thanks for the thoughtful comments Zee, Thomas and Zee!
It would be very helpful to hear more about paint types and such.  Let see if we can get that started!
« Reply #1202 on: September 30, 2018, 04:34:48 PM »
Here’s my update of yesterday’s shop session.
There were a few things left to finish up the Canopy.
First, I filed & sanded down the wood blocks that are the receivers for the canopy supports, then drilled appropriate holes in them, as can be seen in this photo:
Next, I cut out some sheet metal for the end plates.  I double sticky taped the two pieces together and filed them to shape.
After drilling holes for the fasteners, I separated the parts and cleaned them up.  Here are the completed end plates:
I used CA to glue them onto the canopy, then glued the little brass nails I’ve been using for rivets in the holes to look like bolts heads or rivets or some kind of fasteners.
Here’s the finished canopy sitting atop the mostly disassembled tractor:
Following this, I spent the rest of my shop time making up some shelves for my shorter bar stock.  This has been my plan for months, I just haven’t gotten around to it till now.  Hopefully this will make it easier to tell what I’ve got on hand!
Thanks for stopping by and taking a look.
That dreaded painting is getting closer and closer!
« Reply #1203 on: September 30, 2018, 05:08:39 PM »
Looks great Kim!
I need to do some more work in the storage department for the small pieces.
« Reply #1204 on: September 30, 2018, 06:13:24 PM »
Awesome job on the canopy Kim she’s finally shaping up and getting close. Bet your getting excited to she it complete.....did I say ..........l...........like......... :Love:
« Reply #1205 on: October 13, 2018, 06:49:13 AM »
For the last few weeks I’ve been painting. Not my favorite job, but one that needs to be done.
Based on the excellent feedback, I found some Rust-oleum High Temp paint at my local Home Depot.  Since I was going with the Rust-oleum, I picked up a few other paints just to stay in the same family.  I got the High Temp black, primer white, Green and Red.   I got matte finish, since that seemed to be more prototypical. These will be the color for my tractor.
I started with the black (which didn’t need primer) and then primed all the parts that were NOT going to be black (because they did need primer).  Didn’t get a picture of the black being painted, but here’s one of the early coats of primer.
I tend to get too excited and get the paint on too thick.  I try so hard to hold back and say “many thin coats.”  But somehow, I don’t listen to myself and I still get blobs and runs that have to be sanded out and then re-primed.  But I stuck with it and think I ended up with an OK finish.
Here’s a shot of the red batch.  Made all the wheels red.  This seemed to be a common theme in many of the pictures of Case Tractors I was able to find.
With the paining complete, here’s all the High Temp black parts:
The green parts:
And the red parts:
And last, but not least, the huge pile of non-painted parts.
If that leaves too much not painted I may have to go back and work it over again. But this seemed like a reasonable compromise to me.  Guess we’ll see.  Because the next step is to re-assemble the whole thing!
« Reply #1206 on: October 13, 2018, 07:14:06 AM »
Hello Kim,
Colors look real good and it always seems to bring "things" together. The unpainted parts should highlight everything else.
Have a great day,
« Reply #1207 on: October 13, 2018, 11:52:58 AM »
All the parts spread out like that...wow. That's a lot of parts! Lots of parts!!  :ThumbsUp:
Online gbritnell
« Reply #1208 on: October 13, 2018, 12:54:09 PM »
Looks great Kim. It should be very eye catching once assembled. I'll see if I can find the artwork I did for the logos when I redid my engine. I printed them on store bought decal paper.
« Reply #1209 on: October 13, 2018, 03:51:43 PM »
Looking great Kim and when assembled will really stand out.  :ThumbsUp:
« Reply #1210 on: October 13, 2018, 04:22:23 PM »
Thanks Thomas, Pete, George, and Don,
I'm quite excited to get this thing across the finish line.
I've sure learned a lot, but am ready for my next challenge  ;)
« Reply #1211 on: October 13, 2018, 04:24:35 PM »
Looks great Kim!
One assembled the tractor is going to be a real eye catcher.
Offline Johnmcc69
  • Erie Pa., USA
« Reply #1212 on: October 13, 2018, 04:33:32 PM »
 :ThumbsUp:
Nice looking parts there Kim, going to be a beautiful traction engine!
« Reply #1213 on: October 13, 2018, 07:00:44 PM »
Thank you Dave and John!
« Reply #1214 on: October 15, 2018, 08:08:13 PM »
Hi Kim, it starts to be an eye-catcher.
