Quote from: Kim on September 03, 2018, 10:16:29 PMYeah, this is the point in the project where I start getting tempted to say "Hey, I've done enough. It runs, I've learned what I wanted to" and get on with my next project (which I'm quite excited about).I suffer the same problem. I hope you continue. I've not experienced yet but I suspect you'll feel even more satisfied.
Great job! Came out well. I'm still new enough to be amazed at how well brass finishes after being soldered. Pretty neat.
I like your trick with the block and the curved arm to hold the parts steady, gotta make one of those!
Thanks Chris!Quote from: crueby on September 08, 2018, 11:47:42 PMI like your trick with the block and the curved arm to hold the parts steady, gotta make one of those!Yeah, I saw this somewhere else on this site. It does help quite a bit. But the parts still scooted around a bit. I can see why Kozo always uses screws to holed his parts together while silver soldering. It makes a MUCH more positive connection and keeps them from moving at all!But yeah, it does help and I've used it frequently for this kind of thing.Kim
