Author Topic: Steam Tractor 3/4" (Rudy K)  (Read 169517 times)
Re: Steam Tractor 3/4" (Rudy K)
« Reply #1125 on: September 01, 2018, 10:36:14 PM »
The controls look great.
The lock handle was interesting.  :ThumbsUp:
« Reply #1126 on: September 01, 2018, 11:49:08 PM »
Nice! Very clever way to make a lock lever with the little bent tab...
« Reply #1127 on: September 01, 2018, 11:56:59 PM »
Good stuff Kim. It's getting closer but the day!!
Offline Kim
« Reply #1128 on: September 02, 2018, 02:37:16 AM »
Thanks for the encouragement, Zee, Pete, and Bill!
Offline Kim
« Reply #1129 on: September 02, 2018, 10:38:05 PM »
Today I got some time to work on the Governor. This is just a dummy part – made to look cool. Not sure I succeeded in the ‘cool’ part, but I will claim victory over having it done!
One of the things I was most worried about with this was how to drill little holes in 1/8” brass balls.
I’ve seem other people make a special pot chuck, or create other holding mechanisms, but I decided to try my 1/8” M16 collet.  Like so:
It seemed to hold well enough to make a hole, and it was even pretty close to on center!  So I made me 3 of those.
Now that I knew I could drill the balls, I moved on to the main body.  This was made form some 1/4" brass bar stock.  The plans show some cool curvy looking body and I tried to emulate that.  I used a tiny parting tool to put some marks in specific locations, then used some small files to shape it.  Here’s after marking important spots with the parting tool:
And this shot is after dong the basic shaping, then using the parting tool to take down the upper section.
Following that, I made the dummy pulley which would ostensibly be used to make the governor go round and round.  I used a 60o threading tool to make the groove in the pulley.
Then I carved the pulley shaft in the same part.  I could have drilled a hole in the pulley and used 1/16” brass rod for the shaft, but I chose to do it this way so I’d have fewer parts to assemble later.  And its only 1/4" brass, so its not like I’m wasting that much brass.
Here are all the parts that will go into the governor.  The connecting rods for the governor balls are some of the little brass nails (Rudy calls them escutcheon pins) that I have been using for rivets.
Next, I drilled a hole in the body to accept the pully shaft.
Then holes in the top to attach the governor balls.
And here’s the governor assembled. I’ll have to do some clean-up after the Loktite sets.
Well, that’s it for today.  That Governor took a lot longer than it deserves but there were lots of little pieces to it.
Thanks for looking in!
« Reply #1130 on: September 02, 2018, 10:43:03 PM »
Well judging by the pressure gage, you definitely have a “handle” on things, and now we know you have the “balls” to back it up  :lolb: :lolb:. Awesome work Kim  :cheers:
Eric
Offline Kim
« Reply #1131 on: September 02, 2018, 11:00:56 PM »
Eric
:ROFL:
I'm still looking for a good pun comeback.  When I think of it, I'll let you know!  :Jester:
« Reply #1132 on: September 02, 2018, 11:12:09 PM »
Looks fantastic Kim. Small!  :ThumbsUp:
« Reply #1133 on: September 03, 2018, 12:26:45 AM »
Looks pretty cool to me Kim. That's a lot of work in that little thing too.
Offline Kim
« Reply #1134 on: September 03, 2018, 05:45:46 AM »
Thanks Zee and Bill,
KIm
« Reply #1135 on: September 03, 2018, 06:56:32 PM »
Nice work on the extra details Kim, everything is coming together nicely.
Offline Kim
« Reply #1136 on: September 03, 2018, 10:16:29 PM »
Thanks Dave!
Yeah, this is the point in the project where I start getting tempted to say "Hey, I've done enough. It runs, I've learned what I wanted to" and get on with my next project (which I'm quite excited about).  But I'm going to stick with it. I'm going to finish this one off, including painting it (still working on that in my mind).
Thanks for the encouragement from all of you!
Offline 90LX_Notch
    • YouTube Channel
« Reply #1137 on: September 03, 2018, 10:23:59 PM »
That's right, you better completely finish this project Kim.  You are too far in to it with too many followers not to.  This has been a great build.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
Offline Kim
« Reply #1138 on: September 03, 2018, 10:27:19 PM »
Thanks Bob!
I need people to keep me honest about this! :)
« Reply #1139 on: September 03, 2018, 10:36:24 PM »
I suffer the same problem. I hope you continue. I've not experienced yet but I suspect you'll feel even more satisfied.
