I have just had a first go with Fusion 360. Previously I have done 2D with Draftsight and CamBam so I was keen to see how Fusion worked for a sculpted part. Here is my first part as a rendering and as a first cut. I found building the model quite easy (normal software caveats apply) and rendering is just icing on the cake. CAM for 3D I think I have more to learn but the software does what it says it will and no surprises. You can clearly see the track of the 6mm ball ended cutter even after 3 operations. I think I either need a tighter finishing pass for the near horizontal surfaces or perhaps use a bull nose cutter rather than a ball, to leave small steps rather than grooves. Anyway a first step and one I am quite pleased with, the part is to be used in a dog guard in the car.Mman
