Author Topic: The Humble Nudger  (Read 15496 times)
Offline KB
Re: The Humble Nudger
« Reply #15 on: September 20, 2012, 09:21:35 PM »
Had mine out the other day;
« Reply #16 on: September 20, 2012, 09:31:07 PM »
Sadly :disappointed: a nudger is still on the "must make list".
Arbalest
« Reply #17 on: September 20, 2012, 09:40:24 PM »
+1 ;)
« Reply #18 on: September 20, 2012, 10:38:06 PM »
That one is the simplest I've seen so far!
Offline rleete
  • Rochester, NY USA
« Reply #19 on: September 20, 2012, 10:44:50 PM »
I had been meaning to make one for quite a while -ever since Bogs first showed it on another forum - and finally got around to it.  Glad I did, it's a real timesaver.  Sure beats the old method of setting up the indicator, spinning the chuck, tapping the part, spinning the chuck, tapping the part again...
« Reply #20 on: September 20, 2012, 10:54:17 PM »
I've used the back of a boring bar as a nudger....but it eventually scars the part....and if your chuck is too tight to start it can scar it bad.
The bearing is the way to go.
