They may be angular contact, but not a matched pair, or a Universal grind. I'd love to see the adjustment procedure from the manual. It would seem silly to not make these bearings a matched pair for DB mounting. Then you wouldn't care about the preload on these as it's ground into them. Tighten the nut till you grunt and you're done. A cheap and dare I say cheerful solution is to put shims between the two bearings as single bearings are very much cheaper than matched pairs or DU grind.....but it would seem a false economy for a lathe.......to say nothing of a lot of painful work.Dave
