Author Topic: Alyn Foundry 'CHUK' Flame Gulper / Flame licker  (Read 15666 times)
Offline Chipmaster
« on: July 10, 2015, 08:03:10 AM »
Last year I obtained some old castings and remnants of the plans for an Alyn Foundry 'CHUK' inverted flame gulper engine. This can still be seen on the Alyn Foundry website even though the business closed long ago http://www.alynfoundry.co.uk/ (Look at the 'Coming soon' section). The CHUK engine is similar to the Plank flame licker engine in both design and size, fortunately, a friend has a collection of flame gulper engines which includes engines made by Plank. Being able to examine his engines was very useful as I learnt how to make my engine. Having incomplete plans and no example of an inverted CHUK to refer to meant that I improvised some parts of the engine. Machining the castings were straightforward operations except for one which was rather awkward to hold. However, accuracy and a good piston to cylinder fit is essential for this type of engine, a lot of lapping was required here also much lapping of the shutter and diaphragm valves.
Unfortunately I forgot to take a photo of the set of castings before I started and I didn't do this build log as I went along because I wasn't confident it would work or whether I'd complete it in a reasonable time because of other larger model engine projects.
So here's a picture of  the finished engine then I'll follow with pictures of building it.
Andy
51 Flame Gulper engine - Alyn Foundry Inverted CHUK
by Andy, on Flickr
Machining the top of the base,
1 Machining the profile of the base casting by Andy, on Flickr
Cylinder mounting flange - a diaphragm and spring will reside in here and the exhaust exits through the hole in the centre.
2 The cylinder sits on this flange . by Andy, on Flickr
Underside of the base,
3 Underside of the base by Andy, on Flickr
Bottom of the cylinder,
4 Bottom of the cylinder by Andy, on Flickr
The cylinder stayed in the four jaw chuck for machining the bore and I decided the external fins might as well be concentric for further operations down the line...
5 Boring out the cylinder by Andy, on Flickr
« Last Edit: July 10, 2015, 06:14:14 PM by Chipmaster »
Re: Alyn Foundry 'CHUK' Flame Gulper / Flame licker
« Reply #1 on: July 10, 2015, 08:18:09 AM »
8) Nice Engine
Alyn didn't make many casting sets, you were lucky to get that one. Do you know of anyone with the other two in the CHUK range.
Was that Cast Iron as gritty as it looked in one of those photos?
P.S. In case people had not seen the CHUK family I have attached the Alyn Broadsheet which details all of them ;)
Offline Chipmaster
« Reply #2 on: July 10, 2015, 08:44:07 AM »
Good morning Jo,
thanks for adding the Alyn Foundry broadsheet. I haven't seen any other CHUK engines and I have been told that not many Chuks were cast and the Inverted were less than a handful, not even in double figures! Perhaps going public on MEM will encourage other Chuks to come out. I am glad that I made the engine, it didn't cost much and it feels even better when you see how much genuine Plank flame licker engines fetched in recent sales!!
As you noticed those particular castings were gritty but once that was out of the way there were no problems.
Andy
Offline Chipmaster
« Reply #3 on: July 10, 2015, 08:54:09 AM »
Removing the cylinder from the fixed steady. This shows the top end of the cylinder machined for the fixed steady fingers
6 Removing the cylinder from the fixed steady
by Andy, on Flickr
7 Cylinder sitting of the base
by Andy, on Flickr
A ridge had to be machined on the bottom of the cylinder which will be lapped later on for a diaphragm valve that will seal against it. The diaphragm and its spring will fit inside the corresponding recess in the base
8 Cylinder base with a ridge
by Andy, on Flickr
« Last Edit: July 10, 2015, 10:24:33 AM by Chipmaster »
Offline Chipmaster
« Reply #4 on: July 10, 2015, 10:15:09 AM »
Milling the port face, this surface will be lapped flat for the Shutter Valve (ex Stanley knife blade) to open and close the port.
9 Milling the inlet port face
by AGB engines, on Flickr
Crankshaft support casting (couldn't think of a better title). This caused a bit of head scratching working out the best way to machine the casting to register with the top of the cylinder. I milled the central area of the casting flat and drilled it so that it could be attached to a mandrel held in a three jaw chuck.
10 Crankshaft support casting
11 Crankshaft support casting
12 Crankshaft support casting
When I was happy with the fit on the cylinder (which I could check with this set up) I went in with a small tool  to cut through the casting and separate it from the mandrel.
13 Crankshaft support casting
The tool can be seen breaking through in this picture
14 Crankshaft support casting - lathe tool just breaking through
So far so good.
15 Base, cylinder and crankshaft support.
16 Base, cylinder and crankshaft support
« Last Edit: July 10, 2015, 10:26:53 AM by Chipmaster »
« Reply #5 on: July 10, 2015, 10:45:51 AM »
I am beginning to feel the need to make one of these. So that must be an excuse for another set of castings  :naughty:
Did you finish marking up the drawings? I am assuming they are as "good" as the other Alyn Foundry drawings I have, where they do not show the dimensions of the casting only the machining needed  :disappointed:.
Offline Chipmaster
« Reply #6 on: July 10, 2015, 12:38:34 PM »
Hi Jo,
no I just made do with them as they were, referred to my friends Plank engine and made things up as I went along.
Andy
Offline Chipmaster
« Reply #7 on: July 10, 2015, 06:32:52 PM »
This is the inlet port, each end was drilled through with a 1/4" drill and the slot milled out using a 3/16" end mill.
18 Milled Intake port viewed from inside the cylinder
by Andy, on Flickr
And a poor photo from the other side.
19 Milled Intake port.
by Andy, on Flickr
I milled away the base until it was flush with the intake port, I thought that would help to get a burner and flame in close to the inlet port.
20 Milling the base so that it lines up with the intake port.
by Andy, on Flickr
The two ball bearings that support the crankshaft would be fitted in this piece which started out as a 2" diameter cast iron bar.
21 Main bearing housing
by Andy, on Flickr
Machined ready for the ball races.
24 Main bearing housing
by Andy, on Flickr
Bolted together and flywheel fitted.
26 Flywheel mounted on crankshaft
by Andy, on Flickr
The cylinder after a couple of hours lapping.
27 The cylinder bore after lappiing
by Andy, on Flickr
Offline Chipmaster
« Reply #8 on: July 11, 2015, 06:41:32 AM »
The diaphragm and piston were next. The diaphragm or flap valve specified was 0.25" shim formed into a regular octagon 40mm across the flats. As I could only obtain shim from a roll I parted off a cast iron disc 25 thou thick from the cast iron bar used to make the main bearing housing and the piston.
28
by Andy, on Flickr
Cylinder, piston and diaphragm or flap valve.
29 Cylinder, piston and diaphragm.
by Andy, on Flickr
Lapping the diaphragm.
39 Lapping the cast iron diaphragm or flap valve.
by Andy, on Flickr
Diaphragm / Flap valve - edges ground to a regular octagon 40mm across the flats. This seals against the lapped ridge on the base of the cylinder to maintain a vacuum on the power stroke. The valve is octagon shaped so the exhaust gas can pass around the valve as it is located in a recess.
41 Lapped cast iron diaphragm with the edges ground to an octagonal shape.
by Andy, on Flickr
« Last Edit: July 11, 2015, 07:36:04 AM by Chipmaster »
Offline Chipmaster
« Reply #9 on: July 11, 2015, 07:01:00 AM »
Crank web, piston yoke, connecting rod and cam.
The crank web and cam were iron castings, the piston yoke and connecting rod used up stuff from my scrap box.
Drilling crank web for the crank pin.
31 Making the crank web
by Andy, on Flickr
Crank web
33 Trial assembly
by Andy, on Flickr
Piston yoke - machined using a slitting saw, drill and reamer whilst mounted on the toolpost.
30 Making the yoke that will hold the gudgeon pin
by Andy, on Flickr
Piston yoke fitted to the piston.
35 Yoke screwed inside the piston.
by Andy, on Flickr
Connecting rod.
36 Machining the connecting rod
by Andy, on Flickr
Trial assembly.
37 Connecting rod fitted.
by Andy, on Flickr
The profile of cast iron cam was machined by offsetting it in a four jaw chuck.
38 Machining the cam
by Andy, on Flickr
40 The finished cam
by Andy, on Flickr
« Reply #10 on: July 11, 2015, 07:31:12 AM »
That crankshaft support casting looked like fun to mount up for machining but over all the parts don't look too difficult.
Offline Chipmaster
« Reply #11 on: July 11, 2015, 07:47:27 AM »
Yes that was the only awkward part, the engine is so simple it is a great pity the model wasn't more popular.
Not many more pictures of the build to post then some videos of the engine running.
Andy
« Last Edit: July 11, 2015, 05:54:35 PM by Chipmaster »
Offline Chipmaster
« Reply #12 on: July 11, 2015, 08:26:20 AM »
I had to improvise the cam follower, pushrod and shutter valve. I know what I made is crude but it has proved to be effective. I milled a flat on the crankshaft support casting and bolted my cam following/pushrod apparatus to it.
To control or keep the cam follower wheel in the same plane as the cam a flat on the end of the brass collar above the spring acts as a guide against the flat steel bar.
[url=https://flic.kr/p/uaCAt2]
Almost finished
[url=https://flic.kr/p/v7tFVV]
The shutter valve is a Stanley knife blade, ground to shape with a boss attached with silver solder followed by yet more lapping. Lapping was a feature of this engine build. I find playing audio books on my workshop iPod player helps relieve the tedium.
 [url=https://flic.kr/p/uPTvBh]
The lapped side of the shutter valve.
[url=https://flic.kr/p/uQ2zJ8]
I arranged the shutter valve mounting so that it floated on the end of the pushrod rather like the slide valve of a steam engine. The vacuum within the cylinder pulls the shutter against the port face so I just had to adjust and time the opening of the shutter. Here is a picture of a lashed up burner, it's a brass bar with a line of holes long enough for the flame to cover the intake port.
[url=https://flic.kr/p/v6YukL]
As the piston ascends the flame is drawn in through the inlet port, the shutter closes the port as the gas burns inside the cylinder hence atmospheric pressure pushes the piston back down the bore. Excess pressure at the end of the cycle as the piston descends is released via the lightly sprung diaphragm/flap valve across the bottom of the cylinder. I found that if pressure wasn't released via the diaphragm then it would blow past the shutter valve and tended to blow the flame out.
« Last Edit: July 12, 2015, 05:48:51 AM by Chipmaster »
« Reply #13 on: July 11, 2015, 08:35:05 AM »
I like the use of the Stanley blade  8)
 :facepalm: You now have me looking at atmospheric engine casting sets. I noted that Polly Wobbles does a set for the Stockport engine that looks interesting  :naughty:.
Looking forward to the video  8)
Offline Chipmaster
« Reply #14 on: July 11, 2015, 12:47:06 PM »
Hi Jo, I wasn't aware of the Stockport engine so I've just looked it up in Polly Models catalogue and there is a video of one on Youtube. I'm very taken with the model, so much so that I feel drawn towards buying the kit. Now look what you've done!
i'll post the videos of my Chuk when using my pc later this afternoon.
Andy
« Last Edit: July 11, 2015, 02:37:03 PM by Chipmaster »
