Author Topic: Double Tandem Compound Horizontal Mill engine.  (Read 184933 times)
Re: Double Tandem Compound Horizontal Mill engine.
« Reply #570 on: September 25, 2013, 08:17:13 AM »
These were done using embroidery thread because it provided a much finer surface texture and was more to scale than string. I did not do any filling or sanding because that would have lost the texture of the thread on the outside of the pipe that I wanted to keep.
« Reply #571 on: September 25, 2013, 08:28:37 AM »
That's a fine result in every way mate it makes a nice change to see the finished result as when the castings leave us it is unusual to ever know how the build went unless a problem arises. As you mentioned the base plate could I offer one of our cast aluminium base for the double tandem which will be surface ground for all the mounting points just email me at sales@brunell.com if you want to go ahead, by the way no charge. Hope to hear from you soon and well done         Regards  Graham   BSME
Thanks Graham,
You are seriously tempting me with your offer of that plate. I am sure an improved mounting would improve her no end at the moment she is :disappointed:
Offline V 45
  • central PA...USA
« Reply #572 on: September 25, 2013, 01:42:32 PM »
Just SUPER Jo !!! A pleasure to tag along  :ThumbsUp:
