Author Topic: Pin valve air engine (inspired by Chuck Fellows)  (Read 7535 times)
Offline BillTodd
    • Bill's website
« on: May 29, 2015, 10:49:26 PM »
Following on from my design suggestions in Chuck's  New Compressed Air Valve Idea  http://www.modelenginemaker.com/index.php/topic,4928.msg93993.html#msg93993.
This is a piston-pin operated valve that opens to a chamber that is sealed  (at least partially) from the cylinder by the piston-pin.
The pin is tapered and pushes the valve to one side thus keeping the force on the pin low
Just before TDC the pin enters a hole and operates the valve, filling the small chamber with pressurised gas. The pressure is only bearing on the area of the pin until the pin exits the hole after tdc when it escapes to press on the piston.
I've had to rethink the Fellow's exhaust valve to make it work with the above but it is still Chuck's automatic exhaust valve in essence.
I thought it was about time I went a stage further with my designs, and this time make it from metal rather than pixels.
So, based on an unfinished  engine, tonight I knocked up the necessary valves and modified the head and .... well
it works  :whoohoo:
Pictures and video later ( the camera battery is, of course, always flat on these occasions)
Sorry about the quality of the picture (tablet!)
The chamber has to be larger than I expected  - several cm3 and a subtantial part of the cylinder volume (the chamber is missing from the picture below ,it flew off across the bench and has yet to be retrieved) .
The motor idles quite slowly <100rpm but the timing obviously late (too late for  good running) . I think the pin is reaching too far into the head (I may have to re-think the head design.
BUT IT RUNS  :wine1: not bad for a first ever engine
« Last Edit: May 29, 2015, 11:05:16 PM by BillTodd »
Offline BillTodd
    • Bill's website
Re: Pin valve air engine (inspired by Chuck Fellows)
« Reply #1 on: May 30, 2015, 08:15:51 PM »
Pics and video as promised ....
<a href="https://www.youtube.com/watch?v=o0smYDP-TuA" target="_blank">http://www.youtube.com/watch?v=o0smYDP-TuA</a>
« Reply #2 on: May 30, 2015, 08:24:34 PM »
 8)
Offline SHOPGUY
« Reply #3 on: May 30, 2015, 09:13:41 PM »
Simple , but effective.
 :) :ThumbsUp:
« Reply #4 on: May 30, 2015, 10:16:56 PM »
That's a nice runner Bill. What does the plug in the end do as you screw it in and out. Its a little hard to tell from the video? I assume it varies the volume of the chamber but I don't detect a lot of difference in running speed.
Offline BillTodd
    • Bill's website
« Reply #5 on: May 30, 2015, 10:52:38 PM »
I've just been laying in the bath pondering that very point :-)
I think what's happening is that the mass of air released by the valve is not being limited by the chamber volume (my initial assumption) but is limited by the valve opening time and air pressure.
My first attempt had a long pin that kept the valve open too long , but did allow for a goodly chamber full (the efficiency was ruined by the late opening to the cylinder)
I can't increase pressure ATM because of my self-ejecting exhaust port . if i can find time I'll screw the thing inplace and wind up the pressure and see if theory hold true
I also suspect that my exhaust spring is too weak, and that speed is being limited by its opening time .
« Last Edit: May 30, 2015, 10:55:44 PM by BillTodd »
« Reply #6 on: May 31, 2015, 01:34:22 AM »
Good one, Bill. A few years ago  I was experimenting with air impact cylinders. A chamber was charged with air at any given pressure, with a "bleed port" into a cylinder. There was a ring of ports from the chamber into the cylinder, but when the cylinder was at top dead center the skirt of the piston covered the ring of ports. As the small bleed port allowed a small volume of air into the cylinder, the piston began to move slowly.---Once the piston had moved down far enough to uncover the ring of ports, the piston "took off" like a rifle bullet as all the air in the pressurized chamber  released at once into the cylinder. Other than making some very loud noises and scaring myself half to death, nothing came of the idea. I have wondered ever since if this technology could be applied to some form of hit and miss air engine. I don't build "air engines" now, but I wish somebody would take this idea and run with it.---Brian
Offline cfellows
« Reply #7 on: May 31, 2015, 03:19:55 PM »
I've been trying for months to figure out how a palm nailer works.
<a href="https://www.youtube.com/watch?v=kSwrj4yB9e8" target="_blank">http://www.youtube.com/watch?v=kSwrj4yB9e8</a>
It seems to me that the princple would work really well for a compressed air engine.  When the air hose is hooked up, the piston reaches equilibrium with equal pressure on either side.  When light pressure is applied to the plunger, somehow holes are uncovered that suddenly release the pressure on the underside of the piston allowing the pressure on the other side to slam the piston down.  Here is a drawing I made of my Bostitch nailer.
For some reason, I just can't wrap my brain around how this thing works.
Chuck
Offline BillTodd
    • Bill's website
« Reply #8 on: May 31, 2015, 06:28:56 PM »
I feel another animation coming on ;-)
« Reply #9 on: May 31, 2015, 09:18:12 PM »
Chuck--a pneumatic nail gun was the inspiration for my work  on the "impact cylinder". What I did find out was that it is almost impossible to use any normal kind of o-ring for a seal, because it gets stuck in the ports that it has to pass by. Probably a ringless piston lapped into the bore would work best for what I was doing.
Offline BillTodd
    • Bill's website
« Reply #10 on: May 31, 2015, 10:54:02 PM »
Chuck,
Your drawing has to be wrong :-(
For it to work , there has to be a way for the pressure on top of the piston to escape to the outside world (and in a hurry, judging by the sound of those nailers)
Are you sure the inside diameter of the ring valve is a close fit to the  plunger (the grey bit) ?
{edit}  Ah ha NO sorry Chuck  I'm wrong (I'm allowing my piston to drop too far thus closing the bottom port - I have it now ... I think :headscratch:
« Last Edit: May 31, 2015, 11:08:33 PM by BillTodd »
Offline cfellows
« Reply #11 on: June 01, 2015, 05:46:12 AM »
Actually, the top of the yellow part is open.  You can see the grey Cylinder liner through the opening.  In the equilibrium state, the grey part is pushed down as far as it will go.  When the nailer "fires" the grey cylinder liner pops up a bit and air escapes out the top of the nailer.  The ring valve is a close fit to the yellow part and the grey part.  And, in the equilibrium state, the ring valve is half way in between the top and the bottom, partially exposing the rings of holes above and below the ring valve.
Chuck
Offline BillTodd
    • Bill's website
« Reply #12 on: June 01, 2015, 08:59:26 AM »
Thanks for confirming that Chuck :-)  ,I found a patent drawing that suggested the same.
I'll try to finish the animation this evening.
« Last Edit: June 02, 2015, 12:50:48 PM by BillTodd »
Offline BillTodd
    • Bill's website
« Reply #13 on: June 01, 2015, 11:27:00 PM »
This is how I think it works
<a href="https://www.youtube.com/watch?v=buGztIYT4PU" target="_blank">http://www.youtube.com/watch?v=buGztIYT4PU</a>
« Reply #14 on: June 02, 2015, 12:24:42 PM »
I lay in bed thinking last night what a perfect driving force one of those "impact" type cylinders would be for a hit and miss engine. After it fired and the flywheel went into "high revolution speed" mode, the lockout lever would simply interrupt the air supply to the cylinder. While the engine coasted (the miss part of the cycle), the air chamber would have time to recharge. When the flywheel slowed down enough, the governor weights would let the lockout lever return to it's normal position and let air flow resume, and the "hit" cycle would repeat. The air chamber requires a bit of time to recharge with air between shots, and the miss cycle of the engines would give it that required time.
