Author Topic: Endmill storage trays  (Read 3086 times)
« on: May 12, 2015, 10:07:12 PM »
If you need a means of safely storing your collection of end mills, get some inexpensive "stick ice trays", e.g....
http://www.amazon.com/Prepworks-Progressive-International-PLIS-4-Bottle/dp/B00J21CAWE/ref=sr_1_1?ie=UTF8&qid=1431464416&sr=8-1&keywords=ice+stick+tray
They're meant for making long, stick-like ice cubes to insert easily into sports drink bottles but their use for separating end mills is more appropriate.  Amazon has a variety.  Search on the term "ice stick tray".
I got some even cheaper at the local Daiso store (Japanese $1.50 store).  Check your local dollar stores.
Offline tinglett
  • Rochester, MN, USA
Re: Endmill storage trays
« Reply #1 on: May 12, 2015, 10:54:38 PM »
What a nice idea Marv!
I know I have some of those that I got from IKEA.  Gotta dig them up.  Could be handy for the commonly used taps, too.
Todd
Offline PStechPaul
  • Cockeysville, MD 21030
« Reply #2 on: May 13, 2015, 12:08:05 AM »
I had a bunch of loose end mills of varying quality and sharpness that I transferred from larger plastic containers to drawers in a parts cabinet. To protect them from further damage, I cut pieces of thin cardboard (like manila folders or index cards), wrapped them snugly around the cutting edges, and then used tape to keep them in place. Then I crimped over the end, added another piece of tape, and "Bob's your uncle". It's also easy to write the details of the mill on the outside, and the mills can be packed tightly together to save space.
The ice cube trays are probably good for mills you use a lot so they can be accessed easily.
Something else that I might try is using XenoPoly to coat the tips and cutting edges of tools. It is a very soft, pliable, non-toxic plastic material that can be used for confectionary molds, and it melts at about 275-300F. I could probably heat the tool with a heat gun and then push it into the plastic to coat it. Then I could also use the heat gun to melt the coating off, and it is re-usable. It should work well for small items like drills, taps, and reamers.
« Reply #3 on: May 13, 2015, 11:20:44 AM »
Nice Find Marv!
