This post will wrap up the machining for this engine. I started with the piston. A piece of brass was faced and drilled for the piston rod
Then over to the bench where the hole was tapped
The elderberry instructions recommend making a collet to make it easier to hold the piston rod for truing up the piston. I faced and drilled the collet.
Then over to the mill for slitting.
Back in the lathe the piston was screwed on and trued up.
Then I used some timesaver on the piston and lapped it to the cylinder. The next piece was the connecting rod. I turned the piece to large dimension and then turned the small end to size
Then the taper was filed to size on the lathe. (Sorry for the poor lighting in this shot)
Then over to the mill where the ends were squared off and the holes drilled and reamed.
Then the piece was parted off and the piston rod side rounded over on the die filer.
With that part completed all I had left were three pins. The original plans call for a slot head but I decided to make mine from hex stock. All three pins were made the same way so I only photographed one. I started by turning the threaded area.
Then I undercut the back end of the thread with a grooving tool.
Then the thread was die cut using a tail stock die holder.
The rest of the pin was turned to size and then parted off.
After completing the pins the machining was complete. I took some time and made a base for the engine. I will leave this part of the build with a final family shot.
The next steps are to fit, polish and blue the parts and put them together. Till next time.
Tony
