He was going to get the window seat but he is as big as the Colchester, then he wants another 13" on the left to allow the collet closer to be removed and I am trying to avoid moving that wall
4 inches surly you ment 100 mm , but you had me going for a moment
Are are you only thinking of moving it the width of the third window pane?
I think I would do as above and then when the bigamist Bridgeport turns up put a dogleg in the partition where you have the pillar drill and just move the partition beyond that.
Your assembly bench would be where you currently have the PZ and lets face it these little aero engines don't need a lot of room to assemble
