Author Topic: FLY WHEEL  (Read 3758 times)
Offline Davis2x1
  • Retired Mechanical Engineer
FLY WHEEL
« on: April 08, 2015, 10:22:53 PM »
Starting to look at my first engine kit. Its a vertical "coke bottle" steam engine.
The fly wheel is cast with no finished surfaces. Any help with the proper sequence for machining would be appreciated.
Thanks, Dave
Sherline Mill and Lathe
Re: FLY WHEEL
« Reply #1 on: April 09, 2015, 01:22:35 AM »
Post a pic of the casting .
Offline Thor
Re: FLY WHEEL
« Reply #2 on: April 09, 2015, 05:18:41 AM »
Hi Dave,
 This was discussed recently on the Model Engineer forum - see here
Thor
Offline Davis2x1
Re: FLY WHEEL
« Reply #3 on: April 09, 2015, 09:33:14 PM »
Attached Photo of fly wheel.  3 inches in diameter. Also have one that is 2 inches in diameter.
Looked that the link and got some ideas. I have slotted face plates that I can use. Turn the OD and then chuck the OD to finish the hub and bore??
Re: FLY WHEEL
« Reply #4 on: April 09, 2015, 09:40:37 PM »
Here's how I have done it in the past...
Chuck/mount to faceplate, rough center and machine SIDE of wheel flat.
Remount wheel using flat side to register and face second SIDE.
While still mounted, drill, bore and, if needed, ream center hole.
Mount wheel on suitable arbor and turn wheel circumference, guaranteeing that rim will run true when wheel is mounted to engine.  [Nobody likes to see a wobbly flywheel.]
Re: FLY WHEEL
« Reply #5 on: April 10, 2015, 12:56:26 AM »
If your 3 jaw chuck jaws will fit inside  between the spokes that's a good way to hold for the first side, rim, and bore.
Offline Maryak
Re: FLY WHEEL
« Reply #6 on: April 10, 2015, 03:31:11 AM »
The success of any machining operation is helped on hell of a lot by doing as much as possible with the first setup. This hopefully leaves the remaining setups with references/datums and removes a large number of possible errors in the completion of the job.
IMHO think long and hard about the final result and the best way to hold the job to do as much as possible before changing to the next phase(s).
HTH
Best Regards
Re: FLY WHEEL
« Reply #7 on: April 10, 2015, 04:10:36 PM »
Given that your flywheel has spokes, an alternate approach is to lash the flywheel to the faceplate by clamping on the spokes.  With a sacrificial plate between the flywheel and the faceplate you can machine one side of the flywheel, drill/bore/ream the shaft hole and machine the rim in one clamping, thus assuring concentricity between bore and rim.
