Author Topic: 1/4 scale Gade engine completed !  (Read 8638 times)
Offline cheepo45
« on: March 06, 2015, 01:27:43 AM »
Hi everyone,
 After almost 5 years of on and off (mostly off!) work, I have completed my Gade model.
Here are some pictures.
The Winter weather has given me lots of shop time. Now that this build is done, I have a lot of cleaning up to do.
I still have to make the cylinder oiler. I hope to finish it by Cabin Fever.
Now I have to get it to run reliably! I'm having some issues with carburetor flooding and the spark plug not firing well.
I'll get it worked out soon I hope.
cheepo45
Re: 1/4 scale Gade engine completed !
« Reply #1 on: March 06, 2015, 01:41:25 AM »
Cheepo,
I have to say that your engine looks really good. Good luck getting it set up & running properly.
« Reply #2 on: March 06, 2015, 01:59:12 AM »
That's beautiful Scott. I am looking forward to seeing it at CF. Great pictures too! Well done.
Offline 90LX_Notch
    • YouTube Channel
« Reply #3 on: March 06, 2015, 02:25:38 AM »
cheepo45-
That's a sharp looking model.   Like, Bill, I look forward to seeing it at C.F.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
Offline philjoe5
« Reply #4 on: March 06, 2015, 03:23:36 AM »
Well done Scott.  See you and the Gade at CF
Cheers,
Phil
« Reply #5 on: March 06, 2015, 07:38:11 AM »
That's a nice looking engine  :praise2:  :praise2: Is that a self made sparking plug?
Offline sshire
    • LS Editions
« Reply #6 on: March 06, 2015, 11:46:02 AM »
Beautiful engine. I'm sure it will be running perfectly by CF. How about a finer thread on the carb adjust. 256 TPI on the HLV-H should be easy  :ROFL:
What's on for the next 5 years?
Best,
Stan
« Reply #7 on: March 06, 2015, 12:01:17 PM »
Looks good, I usually cut a shallower point angle on the needle valves than shown on drawings to make them less of an on/off affair.
As I said on the other side, you may want to lift the fuel tank, it could be you are having to open the needle more than needed to get it to suck up fuel which then causes flooding. Full size and 1/2 scale Model Gades have the tank on the bearers not below
Offline cheepo45
« Reply #8 on: March 06, 2015, 01:03:10 PM »
Hi Everyone,
 Thanks for your compliments!
Yes, the spark plug is homemade. I drew up a design and made it using a corian insulator. I wanted to make it as small as possible for a scale appearance. This led to some interesting challenges - especially trying to see what I was doing! I think the insulator is cracked inside, which may be the cause of the intermittent spark. I have another snow day today, so I will make another spark plug and see if it helps.
I did have the fuel tank on top for the test run, but the fuel level was higher than the fuel inlet on the carb. I couldn't put hardly any fuel in it without it running out of the air intake. I would have preferred a higher tank mounting for a more scale appearance. Once I get it running properly I may make another flatter fuel tank and remount it.
I am also experimenting with a much shallower taper on the fuel adjustment screw. I wish I could retap it for a finer thread, but it's already tapped to a 2-56.
My biggest priority right now is to get it running well for Cabin Fever.
cheepo45
« Last Edit: March 06, 2015, 01:07:43 PM by cheepo45 »
Offline RayW
« Reply #9 on: March 06, 2015, 03:21:11 PM »
Great looking engine. Can't wait to see some video of it running. Is it built from a kit of castings and if so, who are they from?
RayW
Ray
Offline cheepo45
« Reply #10 on: March 06, 2015, 04:13:21 PM »
Thanks, Ray.
 The casting set came from Gary Martin. ( www.martinmodel.com )
The castings were very nicely done.
I would highly recommend them.
cheepo45
Offline metalmad
« Reply #11 on: March 06, 2015, 08:04:24 PM »
Hi Cheepo45
She is a Beauty  :praise2:
« Reply #12 on: March 06, 2015, 08:25:44 PM »
Ray, there are also 1/2 Scale castings done by Robert Campbell  and a suitable cart kit by Iowa Miniature Engines. I'm building both at the moment :)
« Last Edit: March 06, 2015, 08:47:42 PM by Jasonb »
Offline rudydubya
  • Western Arkansas USA
« Reply #13 on: March 06, 2015, 10:04:53 PM »
Beautiful engine cheepo.  Congratulations on a fine build.
Rudy
« Reply #14 on: March 07, 2015, 12:25:03 AM »
Engine looks great Scott, is there a video we can watch?
