Author Topic: Magic Sticky Stuff  (Read 10305 times)
Offline gldavison
  • Tarkio, Mo.
Re: Magic Sticky Stuff
« Reply #15 on: February 22, 2015, 02:07:14 AM »
Darn pricey stuff. How big is that 90g stick.
I am wondering if a hot wire will cut thin slices of this stuff. Seams is should. I would think this would make for less waste.
Gary
Windows 10 & 11, Alibre Design Pro V27, IntelliCADPro6, CamBam, Mach4, 3D Printers, Cetus, Anet ET5 X
15" South Bend, 10" Logan lathe, Grizzly square column mill, CNC router & Hot wire cutter. Lagun FTV-1 knee mill, Sherline mill & lathe
Offline sshire
    • LS Editions
« Reply #16 on: February 22, 2015, 02:23:28 AM »
About 1" in diameter by 8".
I put it in a plastic bag on tapped on the end to break off some tiny chunks which will live in the bag with the stick. The pieces I used were about the size of a grain of rice. The 90gm should last me for years.
It's about the cost of a decent end mill.
Best,
Stan
Offline PStechPaul
  • Cockeysville, MD 21030
« Reply #17 on: February 22, 2015, 03:15:28 AM »
Is it also reusable by chipping or melting it off the workpiece and work holder in the chuck? Seems like some good stuff!
Offline sshire
    • LS Editions
« Reply #18 on: February 22, 2015, 04:06:32 AM »
i did that, Paul.
When I removed the penny with heat, the CB , after cooling, chipped off the aluminum. I threw it in the bag.
Best,
Stan
Offline krv3000
« Reply #19 on: August 01, 2015, 08:47:38 PM »
ooo brill
Offline Ian S C
« Reply #20 on: September 02, 2015, 01:15:14 PM »
A bit OT, when I got my new lathe, I took two pennies (NZ, same size as old UK), put them in the 3 jaw chuck and faced the tails side off each of them, then sweated them together.
Ian S C ::)
