Author Topic: The Beeleigh Mill, Woolf compound engine.Maldon, Essex.  (Read 158932 times)
« Reply #195 on: February 23, 2016, 11:22:21 PM »
this is the video link of the meshing gears also the gears inside the frame awaiting the bearing blocks and the rest of the governor..........more 12BA bolts to make.......
« Last Edit: February 23, 2016, 11:30:07 PM by steam guy willy »
« Reply #196 on: February 23, 2016, 11:31:57 PM »
Nice job on the gears!
« Reply #197 on: February 23, 2016, 11:33:29 PM »
What did I tell you, piece of cake wasn't it? Your the man Willy......... :praise2:
« Reply #198 on: February 24, 2016, 12:02:10 AM »
Nice gear work!
Online Dave Otto
« Reply #199 on: February 24, 2016, 02:39:45 AM »
Very nice Mr. Willy!
I always enjoy your work.
« Reply #200 on: February 24, 2016, 03:09:13 AM »
Thanks for all the comments  and this latest bout of work may have been due to the full moon over here in Blighty !!!
The bearing blocks now need to be made and the first one is getting there,  and i need to make some 12BA square headed bolts, I usually just use hex bolts and file them off square as there is enough room to do that with an oversize bolt thread.......
« Reply #201 on: February 24, 2016, 03:18:10 AM »
Hi Dave, it is not my work really ,i am just copying someone else's work from 180 years ago !!
« Reply #202 on: February 25, 2016, 07:59:51 PM »
more work on the governor drive train.......the bearings made and fitted next is the gov itself and the pulley part
« Reply #203 on: February 25, 2016, 08:13:51 PM »
Very nice!
« Reply #204 on: February 26, 2016, 12:03:48 AM »
Looks good to me Willy, as long as your happy with it......... :ThumbsUp:
 8) Don
Online Dave Otto
« Reply #205 on: February 26, 2016, 01:21:23 AM »
And a very nice job you are doing of it!
« Reply #206 on: February 28, 2016, 02:29:19 AM »
done a bit more, the Governor pulley, and the A frame adjusting lugs for the wedges.....Also have just been given 66 tins of nuts screws washers and bolts,taps and dies.......mostly old school whitworth and BSF so if anybody local wants any then i will pass them on......
« Reply #207 on: March 03, 2016, 02:28:25 AM »
more work on the governor, i have used square stuff so i could turn the 10BA thread and the extra length is to enable the part to be filed. This governor is a quite simple watt type with a minimum of parts so will be quite easy but a lot of filing. The finished dimensions are .065 " wide and .035" thick.Also i am still not too well with my asthma condition so have lots of new medication to take.....exept i am not allowed to drive or use tools and machinery !!!!
« Reply #208 on: March 03, 2016, 11:13:49 AM »
The filing job looks awesome.
The meds not so much.
Is the asthma a seasonal thing? Hope you improve soon.
Don't need the driving...but the tools and machinery? That's sad.
« Reply #209 on: March 09, 2016, 01:48:10 AM »
Am feeling a lot better now so have done some more turning and filing on the governor......so need to catch up with drawing and finishing off the governor and then making the main and beam bearings........
