The pistons are brass fabrications, I toyed for sometime in making the pistons out of cast iron, but in the end I settled for brass with one piston ring. Because of the holes in the cylinder liner the ring needs to be pegged to stop it rotating. This peg and the gudgeon, or wrist pin bosses are silver soldered into position before final machining. There is no chance of silver solder entering the pre-machined ring groove as all solder is applied from the inside of the piston and the peg is a press fit with a portion protruding inside the piston for the silver solder to adhere to. My best regardsGray,
