Im looking to build a mill engine with a 1 inch bore, in the design the valve box is machined out of the same block so it starts as a 2 inch square.
All okay other than the thought of all the swarf and oil based coolant from machining a block of steel down.
Thoughts moved to making the cylinder from ally (the hard type), not the best of match's though an ally cylinder and a brass piston.
any thoughts or experience guys?
