Author Topic: Bugger!  (Read 7480 times)
Offline tel
  • Bathurst District, NSW, Oz.
Bugger!
« on: August 07, 2012, 10:28:48 AM »
Just when I thought I might start getting a bit of workshop time in my neighbor comes up with this little problem.
Bogstandard
Re: Bugger!
« Reply #1 on: August 07, 2012, 10:39:40 AM »
Don't worry, Tel will fix it :zap:
A bit of chewing gum, loctite and superglue and it will be back again on four wheels in no time.
I used to get jobs like that, I call them 'just' jobs.
"Can you just fix this for me." :hammerbash:
Offline swilliams
  • Canberra Australia
Re: Bugger!
« Reply #2 on: August 07, 2012, 11:16:22 AM »
Geez Tel, glad it's you and not me  :toilet_claw:
Offline tel
Re: Bugger!
« Reply #3 on: August 07, 2012, 11:59:05 AM »
It's the first MF65 I've ever seen break an axle - and finding a replacement half shaft is going to be the tricky bit. I think I can repair most of the mangled 3 point linkage.  :(
Re: Bugger!
« Reply #4 on: August 07, 2012, 12:45:27 PM »
Thinking positively: at least its not in the UK other wise it would have also been up to its axles in mud.
Offline AdeV
Re: Bugger!
« Reply #5 on: August 07, 2012, 06:12:02 PM »
Was this a low-budget privateer attempt to emulate Nasa, by any chance? If so, I'd recommend bigger parachutes...  8)
Cheers,
Ade
I'm just a poor old man. I have no time for law-breakers. My legs are grey. My ears are gnarled. My eyes are old and bent.
Offline AussieJimG
  • Bywong, NSW, Australia
Re: Bugger!
« Reply #6 on: August 08, 2012, 08:00:01 AM »
Try this mob Tel, they are in Sydney and seem to have lots of MF parts: http://www.dieselhub.com.au/shop/index.php?route=product/category&path=218&gclid=CL7ftei517ECFcqTpgodbEEA8A
Offline tel
Re: Bugger!
« Reply #7 on: August 08, 2012, 08:02:02 AM »
Thanks Jim, I'll give 'em a try.
Online steamer
Re: Bugger!
« Reply #8 on: August 08, 2012, 11:02:22 AM »
Tel
What is that thing on the back of it?....is that a home built dozer blade? :hellno:
I trust you have another tractor to pull that one out with.......changing an axle in the dirt bank isn't going to be any fun......
Online steamer
Re: Bugger!
« Reply #9 on: August 08, 2012, 11:07:00 AM »
I'd look at the outboard bearing mounts very carefully...as well as the axle seal seats......if the shaft is twisted....that's going to really suck getting apart.
Not familiar with that tractor. but I trust the outboard bearing housing is seperate from the axle housing.....you got a hope then.
Online steamer
Re: Bugger!
« Reply #10 on: August 08, 2012, 11:07:58 AM »
.....might want to put the heat shield on the other side too......
Offline tel
Re: Bugger!
« Reply #11 on: August 08, 2012, 11:51:33 AM »
Yeah Dave, getting 'er out of the gully was Sunday's job - towed out OK with another MF once we got a log set up as a skid over the front axle and under the rear one, then pulled it up level with the other MF and chocked it all up to a workable height. The bearing housing is separate to the axle housing proper - probably 12 or 14 bolts to undo around 'er.  Don't think there'll be any real trouble pulling the shaft but you never know til you get in there a bit.
It's a very similar set up to this 'un.
« Last Edit: August 08, 2012, 11:54:58 AM by tel »
Offline tel
Re: Bugger!
« Reply #12 on: August 08, 2012, 12:00:39 PM »
Got it in one - and the cause of all the trouble, whoever built it made the links too short so it only just clears the rear tyres - coming up out of the gully it picked up the tyre, which pulled it up pretty near to the top of the wheel before the wheel stopped and the axle kept going. Smashed up all the r/h side of the 3PL in the process.  :( I gotta get an indoor hobby!
Offline Maryak
Re: Bugger!
« Reply #13 on: August 08, 2012, 01:24:03 PM »
Gee tel,
I thought it was a carry all that had tangled up with the wheel, if it's raining your way like it is here, I'm glad it's you - not me.
What is with us guys ?
I didn't take any photos but last weeks job was a forklift side shift support bar. Your average shipping container has a tare around 3000kg. My partner's son thought he could hook one fork under the corner and side shift it into place with a 1.5 ton forklift. He did manage to side shift the forklift up to the point where the support bar gave way. 2" x 1/2" cast steel bar with guides and locking hooks. Snapped it off about 1/3 of the length which is around 2' 6"
First lift off the forks, easy enough, then lift of the carrier frame, bloody heavy, then an overall covering of us and the surrounding area in diabolic oil to remove the ram and finally the side shift bar fell off in its' two pieces.
Did I ever tell, no pun intended, how much I hate welding cast steel. Much faffing about with a blow lamp to preheat it then a couple of tacks, then checking for square with my asbestos rule and fingers finally grooving and welding. Fag time while it cooled then put it all back. All up a bit under 3 hours.
The impossible we do immediately, for miracles wait 10 mins.
I suppose I should be grateful at least I was inside on a concrete floor.
Best Regards
Offline tel
Re: Bugger!
« Reply #14 on: August 08, 2012, 10:55:17 PM »
Oh yah, a concrete floor and some sort of roof would be real nice, so would a bucket of sovereigns but .......
Hosin' down here this morning as well - the job will have to wait.
