Part 4
These are the shop sessions that try men's souls
As you can tell from the title this was not a good shop session. It started out ok. I cleaned up a piece of brass rod to make the pistons from
Then I turned the middle diameter of each piston. That was more than a little hairy. In retrospect I should have turned them between centers.
Then it was into the collet block and over to the mill to drill the crank pin hole
Then the crank end was milled to width
Then back to the lathe for parting off.
When I parted the pistons off it felt weird. At the time I discounted it as the normal problems I have with parting brass. Next up was the 2 crank disks. I put the stock in the lathe and cleaned it up.
Then I drilled the stock for the shaft.
Then it was put unto the collet block and the crank pin hole was drilled. The original intent was to drill the holes for the center and crank pin deep enough that I could just part off two crank disks from the same stock. That way there would be no possibility of the throws being off.
Then it was back into the lathe for parting off..
That's when my trouble started. I could not get that piece parted off no matter what I did. I reground the tool I changed speeds nothing. That's when I realized that the parting tool was slipping in the holder. I went to retighten the holder when I realized the adjustment shaft was stripped out. I finished cutting off the crank disk using my hacksaw and I moved it over to the mill to drill for the grub screw
I started the tap using my mill and then moved it over to the vise to finish tapping the piece. I then proceeded to snap off my 4-40 tap in the hole. I took that as a sign and stopped for the week. I'm traveling for the next 10 days and then I need to order some tools so it will probably be a few weeks before I get back to this build log.
Tony
